Old 03-07-2016, 11:13 PM
john hall's Avatar
Good to know about the Dekka/O'reileys connection. I've bought about 3 larger batteries from them in the last 2-3 years. O'reileys has a pretty good rewards program for frequent customers as well.
Very interesting write-up regarding more CCA in the same size case possibly being a tradeoff for longevity.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 03-10-2016, 01:51 PM
Originally Posted by Shotgun Wedding View Post
I've always believed the opposite what is stated above, that the higher the CCA of a battery, the better it is and will last longer. It is a misleading statement when all things are considered. In terms of robustness, a lower CCA battery will be more robust than a high CCA battery given same case size.
First, the higher the CCA of a battery (and let's assume the plastic-cases are all the same dimensional size for comparison), a 400CCA battery as compared to a 250CCA battery will have to have more lead plate surface area, thus thinner lead plate thickness to fit into the same case in order to achieve the extra CCA capacity. Thus, a 250CCA battery will have thicker plates in the same sized case as a 400CCA battery. The 400CCA battery will give more CCA, but at a cost of thinner plates and less space between plates for electrolyte.
Everything you have posted above is possibly true except for one thing. You're assuming the battery case, whatever size it may be is stacked full of plates, whether they be thick or thin. This isn't the case at all.
Here is just one brand of battery that has an economy battery and a premium battery in the SAME SIZE case. 7 5/16", 7 3/4" long and 5 13/16" wide.
The cheapo is listed as a U1-1
160 CCA
200 CA
Weight 15 lbs.
The premium battery is listed as a U1-3
CCA 340
CA 375
Weight 17 lbs.
As you can see, the manf. is getting 2 lbs more plates in the premium battery than the economy whether it be thicker or thinner plates. Bottom line, there is extra space in the cases to provide more capacity.
Per my recommendation above, I always buy the premium battery here. Usually costs about 30% more but I find the reserve and the longevity is worth it.
Here is a link I used as a reference.
http://shop.advanceautoparts.com/p/a...u1-3/2050013-P
Old 03-13-2016, 08:37 AM
drcjv's Avatar
drcjv drcjv is offline
I just bought an interstate SP-40 at Home Depot for $49.97 350CCA. One thing to be aware of is how long the battery was sitting on the shelf. They had batteries that were over a year old. I made them go in the back and get a battery with current date stamp.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 03-13-2016, 09:26 AM
longislandcubs longislandcubs is offline
I personally have had a lot of success in the U1 group utilizing the Diehard Gold . Most of my Cubs are using model # Ul 50785, With 340CCA. I think it has helped that I use a battery tender when not in use.
Old 03-16-2016, 03:46 PM
I was just on the way to the auto parts store to pick up 2 batteries. And who pulls out in front of me but the Interstate truck. Got 2 fresh 300 CCA's for $44.94 ea. right off the truck.
Old 03-16-2016, 03:56 PM
Terry C's Avatar
Terry C Terry C is offline
Can't beat that.
Sweeting the deal on the Cubs you are selling?
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 03-16-2016, 03:59 PM
Can't beat that.
Nope, these are going in my 2 Swisher tow behind mowers. Almost time to cut grass although the weather guesser is calling for snow Sunday.
The deals on the Cubs are as good as they are getting. Most of the guys on OCC and other sites want Ultra Cheap deals. Then they dump a ton of $$$ into them but they got them cheap. My stuff has already had a ton of $$$ dumped into them.
Old 03-16-2016, 10:15 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
You did good Sam!!
Jay
Proud owner of the following:
Old 03-16-2016, 10:23 PM
jaynjeep's Avatar
You hit the nail on the head Sam.. when you buy one ultra cheap get ready to sink some $$$....
The 2182 we got from you last year hasn't missed a beat!! But you had already sunk mucho time and $$$ into it... I still consider it a great deal because we were able to bring it home and put her straight to work!
The 1782 I bought cheap elsewhere.... I'm bout there... but I have sunk some time and $$$ into it!
I wouldn't hesitate to buy another one that you have had ahold of!!
Jay
Old 03-20-2016, 02:20 PM
Hard to beat this:
http://rebate.ruralking.com/weeklyad...-img-weekly-ad
