Old 08-04-2010, 05:18 AM
animal animal is offline
Default cw-36 snowthrower shear pin
I just got a cw-36 in good shape to mount on my 126. I looked up the shear pins since its serial # is above 111001 and found that IH-102677 is not available. Any thought where i can get some or a suitable substitute?
Old 08-04-2010, 06:46 AM
I would suggest that you try here..... McMaster-Carr.
Look at the "coiled pins".
Old 08-04-2010, 09:02 AM
Don't think a coil pin is going to work here. The button head is held in by the metal clip.
Old 08-04-2010, 02:09 PM
bsyphrit's Avatar
bsyphrit bsyphrit is offline
do not know it this helps but for a shear pin on my woods mower deck i use a low grade bolt like a grade 2-3 . on my unit it takes a 1/2x3 bolt and i have been using these for 10 years now without a problem, and yes they will shear off if you push them beyond there limits. as a matter of fact if you have the rpms up and engage the pto to fast just the tourque from starting will take out the 1/2 inch bolt.
i just go to TSC and get there cheapie bolts for shear pins.
Old 08-05-2010, 03:03 PM
Mountain Heritage's Avatar
Isn't that a rivet? Looks like it to me - not really a shear bolt??
Old 08-05-2010, 05:15 PM
You know what it sure does look like a rivet. Wonder if its aluminum too?
Old 08-05-2010, 05:24 PM
TEET's Avatar
TEET TEET is offline
I agree...looks like a steel rivet to me...I have a bunch just like that in my fastener bins.
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 08-05-2010, 07:35 PM
bsyphrit's Avatar
http://ccmanuals.info/pdf/CW-36%20Sn...20Manual-2.pdf
by looking at the manuel it is a rivet you have there as a shear pin
Old 08-05-2010, 08:02 PM
That's gotta be fun! Have to re-rivet things together in the middle of the night when your freez'n your *&$ off! Nice design, think the bolt would have been a little better???
Old 08-06-2010, 08:11 AM
You don't have to rivet it. It just pushes in.
