I'm looking for ideas to remove the gas stains from the plastic on the IH Lawnboy, I was going to paint it but it work really good under the pines trees so I think I might leave it as is if I can get rid of the stains. The area is part smooth and part textured so wet sanding and buffing it is out.
try a little muriatic acid on a small area and see what happens,use a Q tip
A Mr. Clean sponge/wipe really did an outstanding job on my soft cabs and made them look like new.
Or white vinegar if you're not up to buying a whole bottle of muriatic. Test first with ear thingy. Another thing is Meguire's (sp?) paint cleaner.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Vinegar, baking soda and a tooth brush. Or you may try the stuff they use to whiten teeth? May work, I don't know. Wouldn't think it would hurt anything.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
For plastic and staining from a hydrocarbon, I would give anything with hydrogen peroxide a try. It will bleach mildly as well as attack any residual carbon based material.
Give the Oxy clean stuff a try, give some time to let the peroxide do its thing, maybe 10 mins or so. If you can get your hands on 35% peroxide (it's pretty restricted now due to its power and likability with the mujahideen), put some on with a tooth brush and scrub in for maybe 2 mins max and rinse. Don't get on your self unless there is some skin you want to first bleach, then extricate. |
Thanks for the suggestion, hopefully I get some time this week to give them a try.
IMO try fantastik first. If that doesn't help go tougher.
The 35% peroxide I got from a cleaning supply "facility" after you apply it, let it sit out in the sun for a couple hours, it'll be oh so white.
Since I'm in the chemical field, I got my hands on some 50% peroxide. Pour a bit of that on a wood pallet and it chars first in a few seconds and spontaneously combusts. Pretty cool!!
The 35% on wood will char it black but no flame. They are both pretty powerful. |
| Thread Tools | |
| Display Modes | |
