Having not ever been into one, this is just an observation. Looking at the parts diagram, To me it appears that Snap ring #15 , holds bearing #14 into #16. John and Lew, am I way out in left field?
Gary 1974 1650 50A "budscub" Was my fathers 1969 125 42" 1978 1450 44A dual hydraulics 1984 782 50C dual hydraulics, waiting for vanguard Z-force Cub cadet Zero turn Sears '66 Suburban 10 Sears '66 Suburban 12 2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow 74 "Green 100 "John"
Yes it does,jon.I guess pics are in order for tomorrow.
Maybe this will help- if I did it right
This is about as clear as pond water to me. Hopefully the photos will help. I'm trying to install #15 Internal Snap Ring - Part #716-04098.
1st image shows #14 bearing (with #8 snap ring installed) on #7 input shaft. Note the groove on the side of the bearing, close to #13 planet gear thrush washer. If #15 is installed in the groove on the bearing, then #16 Bearing Cage will not seat into the #1 housing enough to install #19 Bearing Cage Retainer Snap Ring. 2nd image shows #16 Bearing Cage. Note the groove inside the bearing cage. If #15 is installed in the groove inside the bearing cage, then the same issue as above (#16 Bearing Cage will not seat into the #1 housing enough to install #19 Bearing Cage Retainer Snap Ring). Note the damage to the cage at the 6 o'clock position where it appears someone may have tried to force the cage in with a BFH. There is normal resistance from #17 O-ring along the outer rim of the bearing cage, getting it past the groove in #1 housing where #19 Snap Ring goes. |
The cross section that was posted is how it goes together,is the bearing the correct width?
this one is 7/16 or .4375
Just my 2 cents, but judging from Dart1917's drawing....
there is a snap ring on each side of the bearing, one in the groove on the input shaft, the other in the groove in the bearing cage. I would make it that way and then try to put the bearing cage into the main housing without the big thrust washer. If it does go in, something on the other side of the thrust washer might not be right. Else wise, that input shaft is not going far enough into whatever it goes into.
You put the bearing in the #16 housing, install the snap ring to hold the bearing in, then put the shaft through it (but the big washer on the shaft first, and install the snap ring on the shaft. Then you would install the #16 housing into the other housing, then install the seal. I also agree with Lew, check the bearing width. Although, I would think that if your bearing was too wide, then you wouldn't be able to get the snap ring on the shaft. |
Your order of assembly may be holding things up.
The bearing should be installed into the cage first, then #15 snap ring to keep the bearing in the cage. With no other parts in the main housing and no "O" ring on the cage and no seal in the cage, put the huge washer into the housing, then put the cage in, to see if it fits. if it does, great. If not, you gotta find out why. Once you get the cage to fit in the housing correctly, put the big "O" ring on it and put it back in and install the big snap ring. Then #7, #9, #11 and #12 need to be assembled and installed from the other side. The shaft should then go in far enough to install snap ring #8.
It goes together like this. 1 press bearing on shaft,install small snappy ring. 2 install bearing and shaft into housing. 3 install snappy ring in housing. 4 install thrust washer. 5 install planetary gears. 6 install gear # 9 with shoulder facing planetary gears. 7 install roll pin in #9 be sure is flush to the gear . 8 install sliding gear # 10 9 install O ring on bearing housing. 10 install whole assembly into creepy housing. 11 install snappy ring.
For instances like this, where it is difficult to get the cage properly seated into the housing, installing the thrust washer and cage first may make the process easier.
| Tags |
| 128, creeper |
| Thread Tools | |
| Display Modes | |
