Old 05-02-2016, 03:18 PM
Thanks for the info guys, hopefully I can get some more time to work on it later in the week.
Old 05-03-2016, 05:47 PM
I got the holes drilled in the mounting plate and the engine lined right up, I need to measure the distance from the cross member to the driveshaft on an 1811 so I know how thick the spacers need to be under the engine. Once that's done I can wire it up and take it for a spin.
Old 05-03-2016, 08:06 PM
One more pic of the engine sitting in place.
Old 05-03-2016, 10:06 PM
Terry C's Avatar
Terry C Terry C is offline
Try taking the air cleaner cover off where it is. You will see what I mean by sanding off the back
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-03-2016, 10:12 PM
I tried, I'm waiting until I have the engine in its final position until I mod the air box.
Old 05-03-2016, 10:53 PM
Good work Tim.
What are you using for wiring, the original one? If so will you need to modify it any?
Old 05-03-2016, 11:00 PM
Good work Tim.
i have the wiring harness out of an 1811 that i think im going to use since its already setup for a magneto, hopefully that will minimize wiring issues.
Old 05-03-2016, 11:14 PM
It's simple to add a relay to take care of the Mag issue. I would have just used the original ign switch and harness.
Don't forget you need to add:
- A power wire for the coil on the carb.
- A relay between the ignition switch and the starter solenoid. The solenoid pulls pretty hard and it has been found that a relay reduces the stress on the ign switch. You could use the one already next to the battery, but no need for those wires back there, or that one mounted at all. A little simple relay will work.
-IIRC, the V twin doesn't have a rectifier mounted to it. Maybe yours did, maybe not, but don't forget to make sure it's hooked up.
Old 05-03-2016, 11:20 PM
Terry C's Avatar
My CH20 has a rectifier. It's on the left side and low. Well, left side as its
sitting in the tractor.
Terry
3225
Old 05-03-2016, 11:24 PM
how exactly do you go about hooking up a relay to kill the mag? my engine has a rectifier on it.
