Old 02-28-2016, 10:00 PM
CubyFan CubyFan is offline
Sam,
I have your thread on drilling the case bookmarked. I plan to do it tomorrow.
If there is a next time I will weld on the washer for sure.
Cheers, Rick
Old 02-29-2016, 08:23 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I would be inclined to install a threaded stud in those holes if possible.
That gives me two chances in the future that I will be able to remove what is bolted on.
Especially if I can use brass nuts for the job.
Old 02-29-2016, 09:36 AM
Unfortunately you need to use bolts on the upper holes because that is the mounting point to the frame and the bolts go in through the frame into the trans from the outside.
Old 05-20-2016, 08:37 PM
Eagle Keeper's Avatar
Eagle Keeper Eagle Keeper is offline
I bought a 1440 a few weeks ago. I have three broken bolts. What causes these bolts to shear ? Been restoring Cubs for 30 yrs. This is the newest one I have ever worked on. I love the layout of the tractor. The Briggs is sweet. So these bolts are dry holes,,not wet ?
Old 05-21-2016, 07:26 AM
The biggest reason the break is that they loosen over time and no body ever checks them. The tranny gets to moving and bingo busted bolt.
The bolt holes go into the trans case and they are wet.
Old 05-23-2016, 04:02 PM
All done. Took me all weekend. All grade 8 bolts now.
Old 05-23-2016, 04:09 PM
The trick is heating the bolt boss,,while keeping steady pressure on the easy out.
Old 05-29-2016, 08:40 PM
OptimusI OptimusI is offline
Since these are wet holes, has anyone played with putting longer bolts in and nuts inside the transmission case?
Old 05-29-2016, 08:53 PM
While I'm not familiar with what the inside of the transmission case looks like, as a machinist I know for a fact that back spot spacing can be a pain in the butt. That process is used to make a flat on the far side of a part for a nut, washer or bolt so it can be tightened correctly without undue stress on the fastener.
Old 05-29-2016, 09:21 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
How would a reverse twist drill bit work on this? The heat while drilling and the left handed force, would it help?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
