Old 05-27-2016, 09:21 AM
craney89 craney89 is offline
Default Blades don't engage
Hello all.
I have a Cub 1515. When I pull the PTO knob, nothing happens. Any ideas? Thanks
Old 05-27-2016, 07:08 PM
Lot's of possibilities in no particular order.
1: PTO switch is bad
2: Bad safety switch or switches
3: Bad fuse.
4: Wiring problem
5: PTO clutch is shot.
Time to get out the meter and start tracing where you have power and where you don't.
Old 05-27-2016, 07:40 PM
3: Bad fuse.
4: Wiring problem
Add to the list, belt fell off and tensioner broke/inop.
Old 06-06-2016, 01:24 PM
Today I went to look at it again. I tried to start it and it did nothing. then I remembered that I pulled the wire off the back of the switch, placed it back on and the tractor started. does that tell me anything?
Old 06-06-2016, 01:31 PM
Nope......
Old 06-06-2016, 02:00 PM
I did have a meter with me yesterday and when I was putting the probes in the slots on the piece that attaches to the switch
I was getting a reading on some combinations and no reading on others does that tell me anything.
Old 06-06-2016, 02:10 PM
Doesn't tell me anything. I don't know what wires you found power on and what ones you didn't.
You can't just probe and guess, you have to be methodical.
Unplug the PTO wire, turn the key to the "ON" position (leave engine off). Set someone, or something heavy in the seat. Turn the PTO to the "ON" position and test and see if power is going to the coil. If not, then continue testing backwards until you find the issue.
