Old 07-26-2016, 06:51 PM
yeeter yeeter is offline
Default Cub extermination?? (Likely political post)
A pesky groundhog has taken up home in my wifes flower bed, and she is not overly pleased about it.
My usual method for varmits involves firearms, but having moved out of the country to a more 'civilized' part of the world, I no longer own firearms (plus I have children and no real use for them anymore).
There was a day we would take a flex pipe from the tractor to the groundhog hole and fumigate it with exhaust. I have heard newer automobiles burn too clean for this these days, so was considering trying it with a cub.
Has anyone successfully put a groundhog to sleep with the exhaust from a cub?
What model cub was used? (ya, I know it probably doesnt matter but if there is a particular model with overwhelming support that works better than some other model, it might be an excuse to buy another cub? ) Ok, my wife prolly isnt 'that' naive...
Are there other methods recommended? (the neighbors trapped one, with a fair bit of time and effort and let it loose somewhere else... hmmm... I wonder if that is where mine came from!) I live in a wooded area with no visible neighbors in sight, so its not like houses are on top of each other but still not inclined to discharge firearms.
Old 07-26-2016, 07:45 PM
I'd use a .22 rifle with .22 CB long ammo, it's not much louder than a pellet gun.
Old 07-26-2016, 09:16 PM
Shotgun Wedding's Avatar
Shotgun Wedding Shotgun Wedding is offline
Cabelas sells a high power air rifle at .22cal with 1100fps or a .177 with 1500fps. These are good Varmint rifles for more urban setting, both are break open and give neighbours the felling that it's only a pellet gun. I have the .22, it's just below speed of sound of 1126fps and doesn't give that sonic book crack like the .177.
Kills tree rats and bunnies quite nicely
Old 07-26-2016, 10:25 PM
If it is a 'chuck, the little buggers are quite curious.
A live trap set by the burrow will attract their attention and they will checkout an unbaited trap.
I got 17 last year in one burrow with an unbaited live trap on the edge of one of my soybean fields bordering a city subdivision where I did not want to get someones pet with a lethal conibear trap.
just don't catch a skunk!!!!!
Old 07-27-2016, 07:55 AM
Dryer vent hose stuck down the hole, some small crushed stone around the pipe the help seal it in the hole. Other end slipped over the tail pipe of my 2015 Toyota Tacoma. Let it idle for 30 mins. Problem solved.
Old 07-27-2016, 08:31 AM
Dirty Steve's Avatar
Hava Heart Live trap and a barrel of water. Ger Glug.... No sound or air pollution. Just do it inside a structure/gargage/shed where no neighbor can film it and get you on anything. Then set it's carcass free somewhere else.
Old 07-27-2016, 11:35 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Even modern vehicle exhaust is deadly in a closed spaced.
Old 07-27-2016, 11:39 AM
Mothballs seem to work too 2,3 and crush 1up
my trash being ripped open was raccoon & 4 cubs living in the storm drain opening
And mothballs helped
Old 07-27-2016, 12:56 PM
Tom4981's Avatar
Tom4981 Tom4981 is offline
Electric fence keeps most things out.
Old 07-27-2016, 06:23 PM
TIMCRUTCHER TIMCRUTCHER is offline
I don't use my Cub. I just work on it and look at it. So far it's holding up very well.
