What color primer do you all prefer to use under IH red paint? I've used light gray on some brackets and the red seems kind of pink?? to me. I was thinking maybe brown would be better. Your thoughts?
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
id go with a medium to dark gray, light gray is a pain to cover with red.
The paint expert at the local Napa store, suggested using flat white primer. When covering with red, or any other bright color. He stated that sunshine/light will go thru the color and reflect off the white. Making the color brighter. I am about ready to paint my 656 Wheel Horse. I am going to try his method.
Don B, USAF 1962-1968, Ft. Wayne, IN |
I'd go with the gray primer or a red tinted primer. Ih used yellow primer on their tractors. I used some yellow primer on the yellow parts on my 1200.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
Olds45512 - so what color primer would you recommend?
Olds already answer you on post #2 of this thread.
I'm no professional like he his and he can correct me if I'm wrong. It's all depends on the shade of color you want, you get better result using a primer having the same shade (Light/medium/dark), I have some flat black primer left and try it has a base coat for some yellow cub parts lately and the result was good!
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
the entire painting industry has started using shades of gray for sealer, we have white and black and mix it to the desired shade that will give the paint the best coverage. believe it or not, red paint doesn't cover red primer very well but it will cover the proper shade of gray with ease. for the IH red id recommend something around the charcoal or dark charcoal, if the primer is to light it will either take a lot of coats to cover or it will look good inside but pink outside in the sun.
[IMG] [/IMG]
Thank you Olds. That dark charcoal should yield a nice deep red color in bright sunlight. I'm just a amateur painter but I didn't want a pink tractor.
We painted a IH 140 tractor many years ago and used gray primer--BIG MISTAKE. We had removed several pcs for cleaning and mechanical repairs prior to painting. Used rattle can gray for primer. It was very hard to get all the primer covered with the tractor assembled. If we weren't real careful we would get drips and runs. I had to specifically paint thin coats on those pcs, which was hard since you couldn't really get the gun close enough to target those areas. I was especially glad when the last gun of paint went on that machine. Seems we were constantly going over it with a drop-light looking for areas that didn't cover.
| Thread Tools | |
| Display Modes | |
