Old 08-27-2016, 06:26 PM
twoton twoton is offline
Default Remote grease fittings
Wanted to put a remote grease fitting on one of my tractors like mjsoldcub did here on his 1250;
http://www.onlycubcadets.net/forum/s...015#post260015
Found this at Grainger;
https://www.grainger.com/product/LUB...fill-Kit-6Y742
..but that's a bit much!
Any thoughts out there?
Old 08-27-2016, 06:50 PM
McMaster has the same thing for $41.
You could go to McMaster Carr and piece it together. They have bulkhead fittings, grease fittings, grease hose, adapters..... It's actually a little less to piece it together. I would use plastic air line (available at most part stores) and use compression fittings to connect it. The air line is rated at pretty high pressures. Not that greasing the gear box uses high pressure. It's not too difficult a thing to make really.
Old 08-27-2016, 07:27 PM
There it is;
http://www.mcmaster.com/#grease-fittings/=13wvli4
part number 1395K25
Old 08-27-2016, 09:37 PM
Billy-O's Avatar
Billy-O Billy-O is offline
A good hardware store probably has all the pieces for you to make one cheap.
Plow blade
#2 Cart
QA36 snowthower
Old 08-28-2016, 06:35 AM
I’ll have to go out and check, but..
I’m guessin that the grease fitting in the steering box is a threaded, 1/8 NPT. So,..
2, 5 packs of Miniature Brass Barbed Tube Fittings (McMaster-Carr part # 5454K65) should be enough to do the 4 tractors that I have;
http://www.mcmaster.com/#standard-ba...tings/=13x3a5m
I would need 2 of the two packs of the Through-Wall Couplings (McMaster-Carr part # 5454K86) ;
http://www.mcmaster.com/#bulkhead-fittings/=13x3g4x
If I wanted the chrome look I could go with the same fitting in chrome plated brass, (McMaster-Carr part # 5483T92) for a couple dollars more.
The Tygon tubing is very attractive price wise but as it only has a max pressure rating of 85 psi I think the Crack-Resistant PFA Clear Tubing for Chemicals (McMaster-Carr part # 52705K32) would be a better choice;
http://www.mcmaster.com/#standard-pl...ubing/=13x3l1x
I should be able to reuse the zerk, or for the shiny look add a few stainless ones (McMaster-Carr part # 1293K11).
Now for some pinchclamps (McMaster-Carr part # 6541K34)
http://www.mcmaster.com/#standard-hose-clamps/=13x410z
Barbed fittings 17.44
Couplings 8.34
Tubing 27.50
Pinch clamps 8.84
Plus zerks if you don’t got nun.
Plus the pinch clamp tool if you ain’t got that either
Plus shipping
Enough to do 4 tractors.
Old 08-29-2016, 01:55 AM
Most of the Cub Cadet zirks are "press in" you're probably going to have to tap all the holes.
Old 09-03-2016, 05:41 PM
Just a quick follow up on this;
-Looks like the zerk is a press in type so yes Yosemite Sam, I will be taping the steering box.
-The Miniature Brass Barbed Tube Fittings that I got from M-C came with a really nice ferule with female threads so no need for the pinch clamps!
Old 09-03-2016, 05:55 PM
That's not a ferule.... it's a threaded clamp. A ferule gets crushed.
That's cool it came with that though. It should hold better pressure that way.
