the internet tells me everything from acetone to drain cleaner..E85..(not available in my state) so what have you guys used that worked?
Okie 105 Project Album (Lots of pictures will be added as each section is taken apart, maybe it can help you get yours back together) ![]() https://flic.kr/s/aHskC461kS
I have used Lacquer Thinner in the past and it worked well for me.
I've never used the stuff but some people claim to have used CLR with good results.
I clean tanks at work with acetone, it works great and drys fast.
Lacquer thinner or acetone,
Throw in a handful of small nuts and or bolts. and shake, shake, shake. inspect and repeat if necessary.
Thank you guys, I happen to have a gallon of acetone leftover from a concrete countertop project.
If the tank has any rust inside of it, consider using a phosphoric acid wash.
It will leave a black iron phosphate coating that protects the metal. I'm in the process of cleaning a 19 gallon tank from a 67 IH Travelall using this method.
PLEASE CONTACT ME BY CLICKING MY USER NAME ABOVE. 1968 Cub Cadet 124 with deck and #2 Trailer 1965 IH Scout 80 Champagne Edition 1968 IH Travelall 4x4 and factory PTO winch 1955 IH Refrigerator |
Vinegar works good on metal tanks, I've used it. Works great on bolts too!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
I use denatured alcohol. Is this a metal tank? If you add nuts or gravel as some may suggest, I would be concerned about promoting rust inside the tank. Might be a good time to seal the tank while you're at it?
![]() https://www.amazon.com/KREEM-Gas-Tan...em+tank+sealer More reading on this; http://www.onlycubcadets.net/forum/s...882#post340882
How do small nuts/bolts or gravel promote rust in a tank?? Its a non painted surface in there, it will rust only when water and air a present....... Has nothing to do with a cleaning method.
Tank liners can work, most don't. If they are applied correctly, and you buy good stuff, I have seen them work fine. I have also seen them peel and flake causing way more issues than they were ever worth. The OP didn't say the tank was leaking, so no need for them anyway. Don't ever line/seal a tank that doesn't need it. |
| Thread Tools | |
| Display Modes | |
