Old 09-25-2016, 02:26 PM
Tom4981's Avatar
Tom4981 Tom4981 is offline
Default Liquid filling tires
When Liquid filling tires do go tubeless or do you use tubes?
Old 09-25-2016, 02:36 PM
Depends on the quality of the tire and rim seal. If you have a slow leaker you need tubes. If you nave nice new rubber and a very clean bead seat you can do tubeless.
Old 09-25-2016, 03:30 PM
Tom4981's Avatar
Thanks Sam....
Old 09-25-2016, 04:23 PM
Merk Merk is offline
The only way to go is tubes. Cheap insurance.
Hit a hole and shock the tire(s) you could pop the bead.
Project Uncle Dick
Cub Cadet 70
Old 09-25-2016, 05:31 PM
Agreed.
Old 09-25-2016, 05:35 PM
Tom4981's Avatar
Never thought of that......I may have to reconsider...
Old 09-25-2016, 08:34 PM
danfeste danfeste is offline
Only problem with filling tubes is if you get a puncture you will have to remove the liquid, fix or replace tube, and refill. With tubeless you can stick a plug in it and be on your way. Also if you go tubeless I would suggest installing metal valve stems. Rim guard has had issues with the water in it breaking down the glue that holds the metal core in the rubber tubeless valve stems. And I would imagine using windshield washer, antifreeze or similar liquids instead would have the same issues.
Collection: 100, 71, 128, 169, 582, 682, (2) 782. 1980 Scout Traveler Diesel.
Old 09-25-2016, 08:44 PM
Learned the hard way.
Project Uncle Dick
Cub Cadet 70
Old 09-25-2016, 08:55 PM
Don't know what use you plan on filling the tires for but, the last plow day I was at a guy was plowing and the wheel slipped on the rim and ripped the valve stem out of the tube. Just something to consider as well.
Old 09-25-2016, 09:49 PM
Sounds like his air pressure was too low, or he was carrying too much weight on the tractor itself. On garden tractors, that is nearly unheard of. Larger machines, yes.....
