Old 10-08-2016, 07:45 AM
slim5555 slim5555 is offline
Question 109 Driveline
Hi Everybody, Just purchased a 109 that someone put a k301 in and the driveline was trashed, So I put a new one in and it looks to be about 3/8 to 1/2 inch to high to lineup with the hyd. unit. The motor is a 1985 k301, spec #47504 which from what I researched is for a 1972 IH. and should be the right oil pan. Bolts and Bolt holes in the trans are all like new.(no movement) Can someone please help ?
Old 10-08-2016, 08:36 AM
Help us first with some pictures.....
Old 10-08-2016, 12:39 PM
Default pic's of Driveshaft
Sorry about that, Here are some pictures of driveshaft misalignment as you can see Driveshaft is to far up.
http://onlycubcadets.net/forum/pictu...pictureid=7060
Old 10-08-2016, 01:45 PM
I would loosen the bolts at the differential/transmission and see if I could raise the pump input shaft for better alignment. Short of that not doing any good, you might be able to shim the front of the engine a little higher.
This is assuming you can't find anything else wrong including the correct solid drive coupler on the engine.
Old 10-08-2016, 04:22 PM
Default Did that
I SHIMMED THE FRONT OF THE MOTOR WITH A .080 SHIM AND LOOKED LIKE THE CENTER WOULD ALIGHN BUT THE FLEX COUPLER WOULD BE WORKING A LOT. Did not seam like that would last very long ??
Old 10-08-2016, 04:53 PM
How about loosening the rear end and see if you can raise it.
I would think the pump driveshaft and crankshaft should be line/line and in the same plane. That rear coupler and driveshaft aren't meant to run at an angle to each other.
Old 10-08-2016, 05:04 PM
john hall's Avatar
Silly question, there isn't a bunch of washers or shims between the engine base and the mounting holes for some odd reason is it? You never know what the last guy was thinking sometimes
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 10-08-2016, 07:47 PM
Did you get a new drive coupler on the engine?
As far as alignment, it looks pretty close to me,looks to be an 1/8" off.BTDT
Old 10-08-2016, 08:40 PM
The shaft doesn't align perfectly.... that's why it has flex couplers.
Old 10-08-2016, 08:50 PM
The stub ( small ) end of the driveshaft fits into the rear coupler.
Tags
109, driveline problem
