Old 10-17-2016, 08:49 AM
Dirty Steve's Avatar
Cool looking mod. Keep the pictures flowing.
Old 10-17-2016, 11:13 AM
Nice work, Joe!
Old 10-20-2016, 08:43 PM
Ikea6e Ikea6e is offline
Joe
The newer CH's have removable panels on the blower housing, here is a pic.
I split the blower housing vertically down the middle. Then it’s easy to unbolt each side to remove them to clean out all the derbies.
Works well for me.
Take Care,
Ike
Old 10-21-2016, 09:24 PM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Default Update for Modifications
Well, Sam got me started on this so, I couldn't stop unless I did something to help prevent this in the future.
Modified the shroud per Sam's picture and added some electrical knockout plugs to the bottom of the shroud so that the stuff can come out as it needs to.
I used the foam from an air filter for the cover plates as I didn't want any dirt getting under there, tried just a gasket but that wasn't enough. The foam is glued to the plate just for insurance.
Also had the pleasure of replacing the crankshaft seal as well, that was a big reason for the dirt sticking to everything.
While I had the driveshaft out, I went ahead and took it apart to clean up that coupling and the 4 steel balls/assembly. Let me tell you now, if you have one of these tractors with that type of driveline, do you and your tractor a favor and take those couplers apart, clean and relube them.
Still have a good bit of work to do to get the motor back together and then set it down in the tractor, don't look forward to that tomorrow, that motor is heavy. Getting to old to lift them up out of there anymore.
Enjoy the pics you picture junkies................
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
Old 10-22-2016, 12:05 AM
Hey, good idea right there.
Should make future clean outs a breeze...
Old 10-22-2016, 10:47 PM
BIGMOZEKE's Avatar
Thanks Todd,
Here is what I was referring to about the drive shaft joints being nasty.
I cleaned them all up spotless, completely repacked them and then pumped grease through the shaft before I reassembled them. Just shown' the dirty pics here........so if you have never done yours, you should get to it to help make your driveline last longer.
Joe
1200 Puller[/U][/B]
1864
Old 10-23-2016, 07:06 AM
bugeye bugeye is offline
Wow. Looks crusty and dry. Mine needed attention after about 5 years from new when I removed the engine for cleaning. I also replaced the o-ring and boot on each joint. Used a zip tie to close shaft end. My 1864 gets about 30-40 hours per year.
Old 10-23-2016, 08:38 AM
BIGMOZEKE's Avatar
That grease was just horrible....gummy and dirty. Great idea on the zip tie.
Joe
1200 Puller[/U][/B]
1864
