Old 11-24-2016, 02:18 PM
Looks pretty crusty, much worse than mine was.
Damn shame the way some folks abuse this equipment.
Old 11-24-2016, 02:23 PM
I wouldn't say abuse.... looks like it was just left outside. As in, probably quit and left for "junk". Now, it has been rescued.
Old 11-24-2016, 08:43 PM
If all that holds it together is the fittings I would remove the fitting on the end that the rod comes out of and connect a porta power pump to the other end and use it to push the piston out. Just be carful because it could be messy and come out with some force. Maybe cover it with a heavy blanket or something.
Old 11-24-2016, 10:07 PM
DieselDoctor's Avatar
A word of caution - please don't be tempted to push the piston/rod assemble out using compressed air. The assemble could suddenly come loose and become a missile launched from the tube.
Old 11-25-2016, 12:00 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Agreed!! I did that once with a brake caliper... the outcome was pretty violent...
Sam's idea should work good though.. slow and controlled pressure is the way to go!
Jay
Proud owner of the following:
Old 11-25-2016, 12:30 AM
gdheck's Avatar
gdheck gdheck is offline
Since the rod is junk anyway, just clamp it in a vise and give a yank. It'll probably come out. Sam's suggestion is good and bad. It shouldn't take much pressure to get the parts moving, but when they do move, it could be somewhat violent if you put more pressure than you think on it.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 11-27-2016, 12:10 AM
mattoney mattoney is offline
Thank you all for the suggestions. I've been out of town for Thanksgiving. I was able to hammer the non-rod end out of the cylinder and look down inside. Haven't figured out how to get the rod end out just yet. Tried clamping the rod in my vise and pulling on it like a slide hammer. That wasn't going to work.
I just like taking things apart and figuring out how and why they work the way they do. I've got a hydraulic shop down the road I was going to contact for hoses and the rod. Unfortunately before I posted, I thought the ends threaded to the tube. I tried to clamp down on it just hard enough to torque it but not hard enough to warp the body, but I think I deformed it anyway, just like finsruskw said! Knew better but tried it anyway.
So, I'll just start searching around for another cylinder and not do that same mistake again. Hopefully someone else will come across this and do a better job than I did.
Thanks again and Happy Holidays everybody!
1966 Cub Cadet 122
1968 John Deere 110
1968 Cub Cadet 104
1971 Cub Cadet 107
1975 Cub Cadet 1650
2 Brinly Plows, Brinly Disk, Brinly Grader Blade, Brinly Box Blade, 3-42" decks, 1-50" deck, a Sears 3 pt hitch I bought for $20, a couple dual wheel adapters, CW36 & QA36 snow throwers, 1A tiller, and a partridge in a pear tree.
Old 11-27-2016, 11:46 AM
gdheck's Avatar
You mean you damaged the tube? It has been a while since I had mine apart, but I'm sure that it's just a piece of honed cylinder tube. I don't even think it has an o-ring groove inside of it, just the two holes for the fittings. It shouldn't cost much for a hydraulic shop to cut a new piece, drill the holes and deburr them to avoid cutting a new o-ring.
Old 11-29-2016, 01:20 PM
Yea, I damaged the tube. I didn't even know what you suggested was an option, so I'll look into it. Thanks!
1966 Cub Cadet 122
1968 John Deere 110
1968 Cub Cadet 104
1971 Cub Cadet 107
1975 Cub Cadet 1650
Old 12-05-2016, 03:17 AM
gdheck's Avatar
If you can't find one locally, let me know. I'm sure I can make a replacement for you. You would need to send me the original for a pattern.
Tags
cub cadet 104, hydraulic cylinder, hydraulic lift, narrow frame
