Old 12-09-2016, 08:22 AM
Tom4981's Avatar
Tom4981 Tom4981 is offline
Originally Posted by Mike in SD View Post
Tom, glad the cab worked out. Would like to see some pictures if you get a chance.
Thanks,
Mike
Here's a couple of photo's Mike.....I still have a few bugs in the 102 that I'm working out.
Like installing a temp.heat shield to prevent engine heat hitting the discharge chute of the snowthrower causing it to ice up.
Old 12-09-2016, 11:01 PM
Mike in SD's Avatar
Mike in SD Mike in SD is offline
Nice setup!
The cab turned out really good, I like the LED light bar, I am thinking I need something like that. You can never have enough light when moving snow.
Thanks,
Mike
'62-O, 2-100, 71, 2-122, 2-123, 72, 127, 147, 108, 128, 149, 169, 2-1450, 582, 3-682, 2-782, 1811
1940 Farmall M, 1955 Farmall 300, 1967 Scout 800, Many Scout IIs, 1968 1200c 4x4
Old 12-10-2016, 04:38 AM
Tom4981's Avatar
Nice setup!
Thanks,
Mike
Mounting it was pretty easy, I only had to drill one hole on the bottom of the frame, the rest is bolted using existing holes.
I had it all together the day I got it, the following day I installed it, only took a few hours.
One problem with the light bar is snow sticks to the lens causing it to block the light.....I'll have to think of a way of stopping that from happening.
That was sure a good investment, I'm very happy with it.....Thank You
Old 12-13-2016, 08:04 AM
Tom
You need this!
http://boone.craigslist.org/fod/5895140708.html
Old 12-13-2016, 09:27 AM
Tom4981's Avatar
Sam we had minus 5 this morning, the Cub started right up
Old 12-17-2016, 04:57 PM
Tom
62 here today, the Honda started right up and I went for a ride.
Old 12-17-2016, 06:40 PM
Tom that's a nice set up you have there. I have to admit in the beginning of this thread I had to think about what your abbreviations meant but I figured it out. I will say back to you that the CF winter could be warm and it always is!
Seriously liking your set up though and that LED bar ain't cheap, looks great
Old 12-30-2016, 08:42 AM
Well we got snow last night. Must be at least 1/2" on the ground. Gotta love it, the locals are wrecking all over the place. I 81 and I 77 are parking lots.
Old 12-30-2016, 09:32 AM
Old 12-30-2016, 10:34 AM
Very true Tim.
Up north.
Down south.
BTDT.
