Old 01-13-2017, 11:25 PM
Shotgun Clay Shotgun Clay is offline
Default Wondering about 3 turn steering
Hi, I was wondering what cub models held the 3 turn steering boxes. I read that you can put them in 149 or similar models. Is that true?
Thanks
Clay
149, 125, 100 w/ rear pto, fenders, and hydraulic lift. 5 snow plows, 1snow thrower, #2 ih cart
Old 01-14-2017, 12:41 AM
1811 and similar models had the 3 turn box, yes it will fit in your 149.
Old 01-14-2017, 12:58 AM
Do you need a 3 turn box to get the full range out of a super steer axle Tim??
Old 01-14-2017, 08:28 AM
Dont know.
Old 01-14-2017, 09:49 AM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
I wanna say the arm travel between a 2-turn & 3-turn steering box is the same. The real benefit comes from less force needed by you to turn the steering wheel.
Many guys have said it's like having power steering. Man, that would be awesome.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 01-14-2017, 10:23 AM
I have two 100's with a 3 turn in them, replaced at the dealership, it does take less effort.
I will see if the travel is different from the two and post pics later.
I am curious also...
Up to 534 and counting...
Old 01-14-2017, 10:35 AM
Alright then, I would like to see if it makes a difference in steering too.
Clay
Old 01-14-2017, 10:43 AM
sir_lancealot sir_lancealot is offline
I have a 3 turn column on my 127, and 2 on the rest of my tractors. Outside of being longer (steering wheel sits up higher), it works just the same as the 2 turn. I don't notice much of a difference in effort from the 3 turn to a 2 turn that's properly lubricated.
Old 01-14-2017, 10:47 AM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
I do like my 1811's with the 3 turn steering. But I added the steering wheel spinner. Because it takes 50% more motion to make a turn. Let us know what you do.
Old 01-14-2017, 12:03 PM
guido guido is offline
In my experience it makes a great deal of difference when I have the snow thrower mounted. That is until I hung 160 lbs. of steel off the back.
Alan
Basket Cases: 129, 1450 sold, 1650
125: 48" Mower Deck, Windbreaker Cab
127: 3 turn steering gear, Spring Assist, Sleeve Hitch, 48" Mower Deck, Dozer Blade
147: 3 turn steering gear, Spring Assist, QA36a w/Xtreme Motorworks Wings
