Old 05-18-2009, 02:54 PM
mharrison's Avatar
i've heard of people putting wood screws in a gas tank and shaking it like crazy. don't know how well it works because i've never had to try it. so good luck
Old 07-25-2009, 08:54 PM
Keith in MN Keith in MN is offline
Default Chain and Red Kote
Insert a length of chain. Tumble. Use a magnet or a wire hook to remove the chain. Its easier than trying to remove a bunch of screws or whatever. If it wasn't bad rinse it with diesel and use. If it was really bad, use a product called Red Kote. The prep is critical but it works great. I've used a gallon or more on a large 72 Cutlass fuel tank to seal a rusted seam. Its still sealed 12 years later. I've used less than a cup to seal a rusty pitted kerosene lantern tank. Still sealed 4 years later. I'm going to buy more to do the tank on my recently aquired 100.
Old 01-28-2010, 10:44 PM
wildmantrav's Avatar
wildmantrav wildmantrav is offline
What I've done in the past with my vintage motorcycles is take 1 part molasses and mix with 5 parts water and add to a steel fuel tank (it will dissolve aluminum). The rusted part must be fully submerged. Let it sit for 2-3 weeks, drain and it comes out like new. This works great with anything steel that you don't want damaged from sand blasting. Best thing is it can be reused a couple times and when done dumped out without having to dispose of chemicals. I don't know how it works but I've used this method many times with great results.
Travis
Old 01-31-2010, 04:31 PM
Here is a link describing the molasses method.
http://www.thechopperunderground.com...howtopic=31444
Old 01-31-2010, 05:51 PM
Iluvtruks0's Avatar
I had the radiator shop boil out my tank and then they installed the coating to the inside of the tank. They even came and picked it up for me. 3 years later, still working great. It didnt cost me a dime thanks to connections which make the world go round. I have also tried the chain in the tank method which seemed to work ok, but make sure you have a time and some good stamina.
Just my 2 cents
David in NC
Old 10-12-2010, 02:31 PM
samspops samspops is offline
Cool
I have used Kreem on vintage Triumph,BSA, Norton cycles that i used to rebuild with great sucess, but now i just use CLR (cheaper & one step) to eat away the rust and gunk. Matt had very good pointers as to finish off with diesel to coat the walls. i have used screws and bbs' to breakup the real nasty tanks before i CLR them and wash out thoroughly with water then let dry before i diesel them. CLR seems to get rid of the rust as well as muratic acid.good luck to all!
Original Cub Cadet/creeper/fluid filled ags/3 rib fronts(Third one I've owned)
Ih rear blade and rake
MF 10/3pt/all the toys(sorry but i like it)
MF 12 under construction(sorry but i like it)
IH 560 tractor
'47 Ford 8N Tractor
'85 Ford F 250 7.3 IH idi diesel
'99 Chetech Pug 4X4
Jari Monarch sickle mower
Old 10-17-2010, 05:57 AM
nikster's Avatar
nikster nikster is offline
A friend's son use's this stuff that is an epoxy liner on M/C tanks. Pour it in & slosh it around with ballbearings. Does a good job & puts on a rock hard interior coating in the tank. His Father restored a Simplicity tractor that not only had rust but a few pinole's in the tank.Coated it with the stuff & also did a great job. Beats trying to buy a new tank $$$$$.
Can't think of the name but someone will read this & know? Maybe it's that Kreem stuff? But I know it's epoxy based.
Nik,
Old 10-25-2010, 06:06 AM
nikster's Avatar
Originally Posted by shoe48 View Post
If you use Kreem make sure you do all your prep work as it will turn to goo if you dont , then clog everything up in your carburator , I have seen this many times in motorcycles , I personally wouldnt use it , But have seen some good results ,, Anyone have a copy of the Battery Charger way of removing rust ?? I will have to look for it if not ,,,
A bit busy now & got a new grandson (yesterday) so thats taking up time, or rather screwing up things that I had plans to do.
Give me a day or 2 & i'll start up a new post with pics & how it worked for me,
Nik
