#41
Got a little time in on my 18 today. Mounted my new tires, bolted the frame to the rear end. Put the rear tires and front axle on. I decided on 1.25" square tubing for the spacer between the frame and fuel tank bracket, should wor well. One thing i question is the rear fenders. Will i have to space the footrests too or will they work? I know that supers use a spacer, but are the fenders different than a gt?
#42
Good bit of work done right there.
![]() I don't know about those tires, but my 1811 I picked up had 26" tires on it, and they cleared the fenders, no spacers. They were Tru Powers.
#43
Im not totally convinced that these are the tires ill be using, but given the looks and performance they have with Nightow1's 782, I really want them to work.
#44
Super fenders are different than the GT. They are longer in the front in order to reach the foot pads. I don't see why you couldn't make a filler to go from the fenders to the foot pads.
#45
Thanks Sam, i figured as much. Ill have to see where this goes. Might be trying to jam too much into a gt
#46
My tire plans for my 1864 are loaded 23x10.50-12 Carlisle Tru Power's on the rear and 16x6.50-8 V61 HD 5-Rib's on the front, but that will be a while, I want to run it for a while before springing for new rubbers.
#47
I got the "correct" paint OEM Cub Cadet for a cyclops series but it seems like the original paint is more orangey than the new paint. Whats the deal?
#48
Sorry for the confusion.
#49
#50
Hey guys n gals, built the spacers for my fenders to clear the tires tonight and put my fenders on. I need an extra 1-1/4" to be able to slide my (3) 12v hydraulic selector valves under the gas tank. I was worried in earlier posts that the foot rests would not work out so great, but they seem to be fine. My issue now is that the fenders, albeit the gas tank is not in there, look super rediculous being that tall.
I think that spacing the rear wheels out would help. Not quite sure where this project is going yet. Also got my turning breaks a few days ago
| Thread Tools | |
| Display Modes | |
