Old 03-24-2017, 08:24 AM
ironman's Avatar
ironman ironman is online now
Originally Posted by Dirty Steve View Post
I installed a vent. Got the idea from Sam Mac.
Or you could drill a hole (maybe 5/16") in the cover plate at a point even with the "full" mark on the dipstick. Tap the hole for a short bolt (plug) fitted with a flat rubber washer. When filling, remove the plug to let air escape, when fluid runs out the hole you are at full mark. Insert plug.
Credit to Roland Bedell
Old 03-24-2017, 10:18 PM
DieselDoctor's Avatar
I followed Lew's suggestion today and pulled one of the bolts holding the axle to the frame so that air could escape during the fill process. I had the right rear tire off to gain access to the bolts so that side of the rear was about 2 inches higher than level. I was able to pour oil into the dipstick tube at a steady rate without any blow back, and never spilled a drop! The oil was showing on the stick just below the full mark when oil began to come out the hole from the missing bolt. I then installed and torqued the bolt, installed the rim and tire, and set the tractor level on the floor. I only needed to add about another 1/2 qt to reach full. Other than having a vent installed as also suggested, this method is fast and painless. Thanks Lew and to all the others that responded. I learned something today!
Old 03-25-2017, 06:26 PM
drcjv's Avatar
drcjv drcjv is offline
I have not tried this yet but I was told that removing one of the valves allows the fluid to go in fairly quickly and lets the air out.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
