Old 03-26-2017, 09:04 PM
john hall's Avatar
I just finished a job last week on the small CNC lathe that had a .0003 tolerance on each of the two bearing journals, .0005 on the width and .0006 on the major diameter with a minimum of 16 RA finish. Steel core with aluminum bronze overlay.
They needed two and I put all six within tolerance.
I'm taking the high road at work and doing as much as I can of the tight tolerance work as I will be leaving before they have my replacement.
you're spoiling them, should have sent that one to the grind shop!
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 03-26-2017, 09:12 PM
Yes, it is a grinding tolerance. When I run that job, all questions are asked before I start. The entire shop knows when I'm doing those parts, "Jeff is CLOSED" ( as in leave me alone )
Old 03-28-2017, 12:19 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Wish you the best Jeff!! I'm sure you made the right choice.. Change is good most of the time.. Plus if you leave on good terms i'm sure you could go back at a later date if needed!
All your cub buddies are behind you!!
Jay
Proud owner of the following:
Old 03-28-2017, 06:34 AM
biglefty's Avatar
biglefty biglefty is offline
Good luck Jeff. Hope you don't have to work all those crazy hours as well. You know your getting up there
Old 03-28-2017, 06:42 AM
CSXengr's Avatar
CSXengr CSXengr is offline
Good luck Jeff on your new job. Just don't turn in your notice to us, we depend on your parts too much! You can't be replaced here!
CSXengr
_______________________________
124 w hydro lift, 124 creeper gear, 125,126,128, 129,147 electric lift, 149 w/tiller, 1200, 1450 dual 1650 w/tiller control hydro, #2 Cart, Haban sickle mower, Gannon, 17 cubic inch cart.
Old 03-28-2017, 07:22 AM
JimmyG JimmyG is offline
Good luck in the new job. It takes good skills to hold that on a machine and I am sure those will be missed! I worked in a shop in the 80's that was not heated well and no ac. Seemed like the machines were happier in the spring and fall. I know I was.
Jimmy
Old 03-28-2017, 07:21 PM
ccguy's Avatar
ccguy ccguy is offline
Congratulations Jeff. In your meeting with the "big guy", you demonstrated restraint, respect and class.
All the best.
INTERNATIONAL HARVESTER
- We build the machines that work.
1811/682/782/1440/IH #4/IH QA 42"
Old 03-28-2017, 08:57 PM
You're leading the way my friend
I'm not planning on retiring from helping out my cub cadet friends.
All the best.
I'm taking the high road. I'm doing it to prove I'm a bigger man than he is.
