Old 03-28-2017, 10:44 PM
Looking good bud!
That looked like the Maggy in my 1811. Them suckers run dirty but keep on chugging along.
Old 03-28-2017, 11:34 PM
Yeah, it cleaned up pretty good. Call my dealer tomorrow to place a parts order, then the fun begins...
Good thing is the darn thing runs/ran so good, so theoretically it should run better clean.
Old 03-29-2017, 02:17 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Todd,
Doubt it runs better clean but I sure would bet it runs cooler!!
Nice job with the clean up!
The old Kohler "boxer" opposed twins never have really gotten the respect that they deserve... most of the failures were due to lack of service and or abuse.. I have several that have been really good engines... even got a KT 17 series I that has been running since 1980!
Jay
Proud owner of the following:
Old 03-29-2017, 08:31 AM
Originally Posted by jaynjeep View Post
Todd,
The original KT-17 had a pi$$ poor oil system with no oil pressure reg, they ran @ #5 usually, then folks started them up and flat peddled em, that starved the rods of oil.
Just picture a rod journal being splash lubricated by 30 weight oil, every other revolution, on any day much less cool weather.
Add to that some engines had sat unused a long period of time between uses, and remember when the engine is hot @ shut off the oil is water thin and drips away easily.
As we know the later series 2,and magnums cross drilled the crank for pressure lube to the rod journals and gave them a pressure regulator with at least #50+ cold.
So yes, the old double breasted flathead kohler is a song to appeciate, @idle or WFO with little shake rattle or roll.
Old 03-29-2017, 09:25 AM
SGragg SGragg is offline
Inactive Member
Your power washer did a good job. Engine looks a lot better.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 03-29-2017, 10:02 AM
PaulS's Avatar
PaulS PaulS is offline
It always amazes me that an engine can just keep on keeping on when it is so full of dirt. I just took the engine loose in my 2084 and although thought I kept it pretty clean it also was a mess. You did a great job on yours. Maybe we should call you Mr. Clean.
Old 03-29-2017, 06:02 PM
Forgot one picture... COOL Muffler, but it's shot.
pic upload
Get in contact with Dirty Steve, he just picked up a muffler with a bunch of other stuff. I'm sure he will cut you a Lew deal on it.
Old 03-29-2017, 11:14 PM
Thanks for the heads up Sam, but I have two extra. So that's one part I don't need to purchase.
Old 04-06-2017, 08:50 PM
Back into the 1811 after a week of slacking.
Got all the gaskets, and seal, so it "should" be the end of the oil leaks. I HOPE anyway.
Check out the backside of the flywheel after I got in there with a screwdriver and loosened all the grass and s#$t...
Need to fab up some remote oil filter lines yet. Going into town tomorrow and see if Napa can help out in that department. There isn't anything salvageable on the old ones.
Old 04-06-2017, 08:53 PM
I hope you used some of that 5 dalla paint.
Up to 534 and counting...
