Old 04-17-2017, 09:58 PM
DieselDoctor's Avatar
Default Turbo time!
As I had mentioned in the post of the initial build, my plan was to run a few hours shake down and then install a turbo on my 782D. The time has come! I hope that this will be completed in a reasonable amount of time, and I will take pictures of the progress. So here we go -----
EDIT - I should add the the kit was purchased from OCC member Mike Masharis. The kit is very well thought out and even comes with a short description of someones experience installing the kit. Thanks Mike!
Old 04-17-2017, 10:51 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Let the fun begin.
Old 04-17-2017, 11:43 PM
Old 04-18-2017, 04:59 AM
Dirty Steve's Avatar
You have way too much fun, Doc. I have never heard a Cub Whistle before in person. Now I know I'm gonna have to take a drive someday!
Old 04-18-2017, 08:42 AM
pballard pballard is offline
Default Turbo Time
Looks like your in it for the long haul. Got some questions- did you source the components yourself or purchase in a kit? What is the projected power result when installed? Have you beefed up the driveline? the drive shaft and joints- if you did what did you change up to?
Looks like a cool project- I will be watching with envy. Please keep the pictures coming as you go!
Old 04-18-2017, 09:15 AM
Had a racer friend that had this on a tee shirt.
Old 04-18-2017, 11:05 AM
No need to beef up the driveline on a hydro. Only so much power can go through a hydro, and only takes so much power to drive one. Turbo will help with the load on the PTO, but won't really affect drive power.
Old 04-18-2017, 11:39 AM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Default turbo
Pete I have two whistlers here if you want to here one.It was one of my kits.
Old 04-18-2017, 12:50 PM
you got my attention, but I want to run it for a while and see how things shake out. I still have a few items to address before I can put the hammer down and see how it performs. Could you send me a pm with the kit specifics?
thanks-pete
Old 04-18-2017, 05:40 PM
Regardless of whether the driveline needed to be beefed up or not, I did make improvements. I installed a hydro with the splined input shaft from a Cyclops along with the CV style drive shaft. The adapter at the motor end was supplied by Jeff in PA. The shaft had to be shortened by about 6 inches so I turned a 4 inch long coupler with .750 ID on the lathe then welded it in the middle saving both splined ends of the Cyclops driveshaft. It makes for a nice clean installation and no more spirol pins to worry about.
