Try pulling the spark plug and ground it to the block and start the tractor and check to see if you have good spark
![]() Quote:
You might get lucky and it still works, it is not good for the points either. if you got spark @ the plug it might be ok. Don't fret about leaving the key on, it has happened more times than ppl admit too. To error is human. luck! |
X2 on what George said. If you have kids, take the key out when not in use.
Little fingers like turning things. Chris
1968 104 , service replacement '96 K301, 42" deck 1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck 2007 LA130,21hp Intek v-twin, 48" deck ![]() ![]() |
Welcome to OCC!
Ok thanks the key was on, on purpose for setting timing it was on a half hour tops. Its reading 2 ohms resistance what is typical for a k301 coil???
3.5 ohm coil is what they are supposed to have.
I'm not convinced you set the timing right.... The points should just crack open at the "S" mark. The gap at "full spread" is completely irrelevant. Don't even bother to measure it. It's that unimportant. Just make sure that they break contact at the "S" mark. Don't leave the key on while setting the timing. Just turn it on when you need it. You don't even have to turn the key on. If you use a test light, just hook it up to the positive side of the battery, and touch the probe to the screw where the coil wire hooks to it. No need to fiddle with a multi-meter like in Matt G's post. That way is cumbersome. At this point, I'm not sure what problem your trying to fix... Slow crank speed or what you think is an ignition issue.... checking the timing is good, but why are you concerned with a weak spark? One thing at a time. If you go trying to "fix" multiple things, you may just be wasting money. Lets figure out whether you actually have a cranking issue, or an ignition issue. So...... does it crank? Does it have spark? |
Ok j-mech yes it cranks but too slowly so it either barely gets started or loses too much juice it wasnt sparking on "S" so that was on my list of things nows its all good and at full spread it is the correct .02.... I cleaned up my connections. My coil has 2 ohms of resistance. SO my only question i believe now is whether having 2 ohms of resistance could effect it firing up quicker (inconsistant spark or something) or if I should rebuild my starter? IMO but not 100% im not getting the cranking speed I need to help her turn over but Im not sure never played with a K301 before..... oh and yes it has spark
Let me put it this way.... My starter generatorator is cranking too slowly..
![]() Quote:
I'm not sure you're understanding on the whole point gap thing.... but as long as you're sure the points are just opening at the right time, then I'll drop it. Quote:
Back to the original ideas. Make sure the wiring is good, solenoid is good.... if it is, then yep. Time to rebuild the S/G. ![]() |
Thread Tools | |
Display Modes | |
