Old 11-24-2009, 10:25 AM
thenrie's Avatar
thenrie thenrie is offline
I can see where using car exhaust would be questionable, but the CO2 is actually a safety procedure used in shops. Car exhaust actually has oxygen in it, in the form of water, especially later models with reduced CO emissions. They actually use a CO2 tank to fill the gas tank in shops. It is heavier than air and displaces all oxygen in the tank (and it's not poisonous). Still gives me the willies. Had a gas tank on an old Willys CJ3 that needed repair. That's why I looked into how it is done. Ended up just buying a replacement gas tank instead. Water would be safe, but it absorbs heat so well that it might be hard to solder or weld on the tank.
I guess it doesn't displace [I]ALL[I] oxygen, since CO2 is one Carbon and two Oxygen molecules combined, but the oxygen is bound to the Carbon, so it does not combust.
Old 08-09-2010, 01:19 AM
johncub7172's Avatar
Found it at last! Everything here at Only Cub Cadets can be found. I know there is no problem of mine that someone else has not all ready had. Sounds like I may have done a good job, but have yet to see. Now someone was saying that when filled up with water, that the nipple area steamed up and no solder would stick. I just let my tank air out a good 4-5 days and no problem....I just have been useing the White lt 14.
Old 08-09-2010, 01:25 AM
Thats why my search was comming up empty......."Gas Trank Repair" was mis-spelled "tank". :biggrin2.gif:
Old 08-09-2010, 09:56 PM
fer100's Avatar
fer100 fer100 is offline
Sorry about that! That's called having fingers to big for the keyboard. I never noticed misspelling in Title when I proof read before posting. I corrected the Title for future lookups. Rich
,1 Ariens 934 Hydro with cyclone rake
Old 09-15-2010, 12:36 PM
Default Flatbed Ford,...
Here is something you should read before you begin.
Old 09-15-2010, 12:51 PM
Flatbedford's Avatar
johncub7172,
Thanks. This is helpful. It looks like the threaded nipple on my 125's tank might be the pressed on variety. Does this mean that the leak is likely a crack in the nipple and not the connection of the nipple to the "trank". I guess I have to clean it real well and look for cracks.
Steve,
Former multiple 149 owner.
