Old 05-05-2017, 01:55 PM
Originally Posted by jrichards View Post
So just spray it in and let it sit? Or would it be worth to actually get some oil and poor it in?
I'd get it in a can and pour it in.
Old 05-05-2017, 02:03 PM
jrichards jrichards is offline
Looks like it is about $80 for a gallon! Might be too expensive for something that may not work....but a lot less work than taking it apart
Old 05-05-2017, 02:19 PM
I'd take it apart. If it's froze up, even if you got it to turn, bearings and the chain will likely go bad from the rust anyways.
Old 05-05-2017, 05:38 PM
Here's how to do it...
I hope you like swinging a hammer and have a good vocabulary!!
You are gonna need lots of heat too.
Old 05-10-2017, 05:50 PM
I got the pully off with a lot of penetrating oil and patience. AFT with acetone works wonders :-).
I am stuck on this part now shown in the picture....it moves but I cant get it slide over the rod...? I am I supposed to take this part off?
Old 05-10-2017, 05:56 PM
Get the set screws out of the locking collar and take the collar off before you try to get that retainer/bearing out
Old 05-10-2017, 06:02 PM
Is that done just by pushing the screws into the gearbox?
Old 05-10-2017, 06:29 PM
nra1ifer's Avatar
nra1ifer nra1ifer is offline
On the tiller shaft (that is sitting in the jack stand), that locking collar needs to come off. Remove both set screws.... it should come off. Seems like I had to coax mine off with a gear puller? Just don't get too crazy with it. Maybe some penetrant there would help... could have grown together.
nra1ifer
Cub Cadet 123, Wheel Horse C160, Craftsman PGT9000, Speedex 1631
Old 05-10-2017, 07:06 PM
The locking collar has to come off before you can get the bearing off.
Then the other retainer will come off, but the carriage bolts will fall into the case if you are not careful. The collars are eccentric's and need to be rotated on the shaft once the set screws are loosened with a punch. They could be locked either way, but I'd try turning them clockwise 1st, if they do not loosen with a few medium taps, try the CCW direction. They should lift right off when loose.
What are you trying to do, split the case??
If so, all the locking collars, the outside retainers and all 3 bearings will have to come off of only one side.
I'd take them off of the plate side and not the case side to begin with.
That way, you can get a good look at what's inside right away.
If the chains need replaced (about $40 for the pair at a Case/IH dealer) you will have to take the shafts completely out. You then need to remove the collars from both sides. The retainers on the case side can stay in place to help re-align the shafts when you replace them. This will also aid in making sure everything is lined up The old chains will come with the 3 shafts, it helps to have an assistant to help hole the shafts so the whole chain/shaft assembly can be lifted straight out of the case.
reassemble in the reverse order. I suggest you down load a copy of the parts blow-up for the unit. Will help you figure out how it all goes back together. Aldo the owners manual. It explains how the chain tension is set once new chains ae installed.
The chain tension fits over a shaft on the plate side and will have to be held in place while you lower the plate back into position. Use a putty knife or other similar piece of flat metal to hold it in place while you align the shafts and lower into place.
Get a piece of gasket mat's at your local parts store and make a new gasket. You will need a piece about 12 x 24"
I packed my case with 2 #s of high temp wheel bearing grease before re-assembly.
Goof luck!!
Old 05-10-2017, 11:07 PM
Thanks everyone for the feedback and information. I was able to get the locking collar off, but I can't seem to get the "Flange, Bearing" off of the "Bearing w/o Locking Collar". Below is a picture of where I am at so far as well as the schematic pieces that I am working with. It seems like the "Flange, Bearing" will not fit over the "Bearing w/o Locking Collar" to come off? Maybe I am not understanding what steps need to happen....
