Old 05-27-2017, 10:40 PM
rdwilson rdwilson is offline
Default K-181
The rod that pushes the points open does not move when I crank the engine over, removed the points and held the rob in while cranking, no movement. Any ideas ???
Old 05-28-2017, 07:19 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
point lobe worn away? other problems I've seen, broken cam, badly worn or bent point rod .
scan in the QR code (upper left) or text IHCC to 51660 to follow which shows and pulls we will be attending.
Old 05-28-2017, 10:14 PM
will have to take it apart and see what has happened, no movement at all from points rod. Thanks for the reply !!
