Old 06-12-2017, 08:41 PM
Tom Dowling Tom Dowling is offline
Default 682 battery drain from electric clutch
New member here, this is my first post. I have a 682 that drains the battery when the mower is on (needle pegs to left) after an hour or so. If the mower isn't on it runs and charges fine. I have no experience with electric clutches, is the clutch shot? Or could it be something simple and cheap? Any ideas? Thanks in advance for any help. Tom
Old 06-12-2017, 08:51 PM
First, welcome to OCC.......
I have to ask a question. Please take no offense but we have to know.
Do you have either of these Test Meters.....DVM or VOM....???
If so, do you know to check for continuity and resistance...???
Old 06-12-2017, 09:28 PM
Thanks for the welcome. All I have is a digital multi-meter.
Old 06-12-2017, 09:30 PM
Old 06-12-2017, 10:13 PM
Yes I do know how.
Old 06-12-2017, 10:48 PM
CubDieselFan's Avatar
What is the voltage at the battery with the engine running at Wide open throttle?
Old 06-13-2017, 05:05 AM
Yes I do know how.
OK, good. Go here and check your PTO out..... PTO Test
After you ohm the PTO out, report back and tell us your findings.
Old 06-14-2017, 08:44 PM
Thank you very much for the information. I'll check things this weekend and report back.
Old 06-16-2017, 12:16 PM
my neighbor gave me an owners manual for a 682, it says .010-.015. .020 max
mine is at .015. To check the ohms I check between the wire and ground is that correct?
Old 06-16-2017, 12:27 PM
I disconnected the clutch and between the wire going into the clutch and ground it reads 0.0 ohms
