All's well that ends well!! Good work!!
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights . {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
The different holes for the spring position on the governor arm change the sensitivity. You really should see where Cub suggests they are set. Different applications have different levels of sensitivity. For example, if you set the sensitivity as you would for a generator up on your tractor, you're going to find that the governor works too much. It will jump RPM at the slightest load. You don't want that. You want a nice smooth transition from non load to load. Not a quick "snap". You can set it more sensitive than the Cub manual states, but only by maybe 1 hole. Just depends on what you're doing with it.
Overall, glad you got it running the speed it should be! |
-Ryan
| Thread Tools | |
| Display Modes | |
