Old 07-17-2017, 11:15 PM
Riley Henderson's Avatar
Riley Henderson Riley Henderson is offline
Default 1100 parts
What is the correct gas tank for for a cub cadet 1100 im looking at one for sale the tank is off of it there is a metal one that comes with it like whats on a 149 cub but was just wondering if thats correct or should it have the plastic QL style tank with firewall. The 1100 however is missing the tunnel cover are these specific to the 1100 because of the different shifter layout or will a QL one work with some fancy trimming.
Old 07-17-2017, 11:25 PM
JLM78 JLM78 is offline
my 1100 has a metal one to . Their is a center cover on Ebay for a 1100
Old 07-18-2017, 07:47 AM
The Fuel Tank for the 1100 is a Kohler part, KH-235935 which is NLA.
That tank was used on the these series of Tractors:
* 1X2/3
* 1x4/5
* 1x6/7
* 1x8/9
Old 07-18-2017, 08:26 AM
Ronnie125's Avatar
Ronnie125 Ronnie125 is offline
The tunnel cover is the same as the other QLs.
Edit: Disregard my post and see below.
1975 1000 | 2 snow blades (1 power angle)
1979 1100 | 6 44a decks, 1 38" deck
1977 1200 | Brinly cultivater & moldboard plow
1978 1250 | qa42 snow thrower, IH landscape rake
1975 1250 (parts tractor)
1977 1450
1976 1650 with dual remotes
2007 Husqvarna 2348
Old 07-18-2017, 09:12 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
It is not the same as other QuietLines. The 1100 tunnel cover has a shift pattern cut into the lower portion of it.
Queen Of The Quietlines!
Old 07-18-2017, 09:23 AM
Ronnie125's Avatar
Yes, my bad, you are correct Delta Cub! I had a mild case of headinbuttitis! Can't forget the little flap that keeps you out of 1st too.
1977 1450
2007 Husqvarna 2348
Old 07-18-2017, 11:55 AM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Same tunnel cover as a 482 or a 582 Special
Old 07-18-2017, 09:24 PM
Thanks everybody I will try to load some pics I went and bought it this evening its not a true quietline but it is closely related so it came home with the rest of them. I will probably need some help in the future I never messed with 1 of these before.
Old 07-18-2017, 09:37 PM
I have one for parts. It's been picked over pretty good, but I do have the tunnel cover still. PM me if you need something or want the cover.
