I just picked up this 1250 for $100. It is missing the muffler and PTO; however, I'm only going to use it for parts for my other QL tractors. I already have plans for the engine. It is going to repower my smoking 1250 until I rebuild the engine. I do love my Quietlines!
1975 1000 | 2 snow blades (1 power angle) 1979 1100 | 6 44a decks, 1 38" deck 1977 1200 | Brinly cultivater & moldboard plow 1978 1250 | qa42 snow thrower, IH landscape rake 1975 1250 (parts tractor) 1977 1450 1976 1650 with dual remotes 2007 Husqvarna 2348 |
I love mine too I try to go start mine and run them around whenever I can if your like me your parts machines will quickly multiply. But once you have them you will be suprised how much you san scavenge off of them they seem like they are worth more than what they can be bought for. Very good buy on on the 1250
Yup, I was just out in my barn with my tractors. My 1000 has a leaking axle seal and the the shifter cup needs repaired. The project would have moved along faster if IH would have used bolts instead of big phillips head screws on the foot rests!
Can't go wrong there, good deal!
Yes sir those big screws on the footrests are a real bugger to get off everytime I have took them off there is at least one or more that need drilled out I usually replace them with bolts.
Uh huh! I had one on each side I had to drill and that was after a week of soaking in PB too! New bolts for me too.
They make impact screwdriver sockets for 3/8 drive I'm sure cause I have a set. That's how I get them off.
I may have to invest in some. Good to know.
Wack the head of the screw with a chisel the same size as the screw head, then they come off for me with a BFSD.
I heat them and off they goes...A bit of sanding and a spray can touch up job, good enough for those old turd!
PS: I use stainless steel button head socket bolts like those David Kirk sell, get them from a local motorcycle store.
Gilles. 1988 2072 401 54" hyd angled blade 1988 1872 364 snowblower/C50 deck 1976 1650/QA42A blower/44A deck/standby 1976 1450TS/Sleeve hitch/44A deck/in storage 1963 100 (red)/in storage 2010 Kubota 2380-2/42" infinity deck (engine swap) |
| Thread Tools | |
| Display Modes | |
