Old 08-07-2017, 11:30 AM
Rdlenig Rdlenig is offline
Default 104 has no power
Hello thank you for letting me in the club wanted to ask a question my husband has a 104 cub cadet.. he had it running had turned it off to adjust the Clutch Went to start it back up and there is no power to anything the battery has juice we looked Threw all wires we changed the generator , we changed the relay, we replaced the ignition switch could anyone please tell us what else it could be we been at these tractor for over 12 hours and can't figure out what it is any advice would be welcome thanks
Old 08-07-2017, 11:40 AM
Best advice is to get a test light or a voltmeter and start checking wires, start at the battery and follow the wires until you find the spot where you lose power. Heres a link to the wiring harness.
http://www.onlycubcadets.net/forum/showthread.php?t=35
Old 08-07-2017, 12:24 PM
First, Welcome to OCC....
From what you are describing, I would suggest starting by looking at the Neutral Safety Switch, located in the Clutch Pedal linkage. The switch could be bad or a wire fell off.
See attached image. Focus on item #18. That tab pushes against the plunger on the Neutral Safety Switch.
Check it out and let us know.
Old 08-07-2017, 01:07 PM
Thank you. That's what it is was, the safety switch. Now to figure out how to get to it, to replace it.
Old 08-07-2017, 01:35 PM
Where in PA are you located?
Old 08-08-2017, 10:35 AM
I-H73's Avatar
I-H73 I-H73 is offline
