This PTO clutch does not have the abrasive friction disk like others might have. They are all steel disks. http://onlycubcadets.net/forum/attac...1&d=1502223376
All steel disks.... that's interesting. Bet that thing engages with a bang. What a poor design.
I would definitely get the oil baffle. Go order it now. Any hydraulic transmission oil will work fine. It doesn't have to be IH, or Cub Cadet or even necessarily "name brand" oil. I use a hy-tran from O'Reilly's in my tractors. |
" Bet that thing engages with a bang. What a poor design."
Yes and yes! ![]()
![]() Queen Of The Quietlines! ![]() |
Ok so we have a new problem. When we started putting all the gears and shafts back together. There is a problem with them lining up. In the drawning I've included. The big gear 21 that has the pto shaft running thru it should line up with the upper gear 26. The problem is that the big 21 gear moves forward about 3/16" to much and gets in to gear 29. I purchased a new PTO shaft 9 thinking maybe it was worn and that's why it slid in to far. But not the case the new shaft still does the same. Apparently this tractor has been worked on before and they met the same problem because they tried putting some thin metal shims between gears 21 and 23. The PTO shaft 9 has snap ring groves on both sides of the shaft where maybe gear 21 should ride but no spacers or snap rings are shown in drawing to order. Bearings 51 and snap ring 14 are in side of gear 23. Anyone got any ideas?
7264 drawing2.jpg |
Well, something has to hold that gear onto the shaft where it rides on the splines...... I agree, there is no call out in the parts to show a snap ring, but I'd say there is supposed to be one. How about in the service manual? Does it show or state one in there? Either way, I think I'd put two on it and see if it will all fit together with a snap ring. On that style of shaft, it would likely be this style of ring:
SNAP RING XXAS.jpg |
If seems maybe the PTO shaft might be used for other models because installing clips would not help stabilize these gears. So our new question is it normal for a PTO shaft to be able to move in and out about 3/16"? If we find some shims or washers to take up the slack of the gears the shaft will still slide in and out about that amount. We are at the point of refilling with fluid and putting the cover back on but sure hate to with that much play and slack without knowing if that is normal for this model. Thanks for any help.
I wonder how he made out on the tractor. Did he finally get it to work
Thread Tools | |
Display Modes | |
