Looks like a nice rig! Congrats!
Go straight to the petcock valves and clean them, replace the bungs. All three cyclops tractors i've gotten were gunked up inside the valves and the bungs wet and smelling of gas.
1872 with 50C deck 1862 with 50C deck 1641 with 48GT deck 364 snow blower IH Cub Original with deck GREEN 317 with integral sleeve hitch, front hydraulic |
Thanks, Jonathan. I really like the Vanguard. In the past I thought they were not a good engine but I have now changed my mind. I like it as much as the Kohler Command. It may find a new home in my spare 1864, that has a bad engine.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
I got a chance to look at the 1641 and the bottom of the carb bowl had trash in the bottom. I cleaned it out the best I could. It runs better but still not perfect.
How do you remove the carb on these? I mean the easiest way to remove the carb. I have good fuel flow but I still am planning on replacing the bungs and replacing the fuel lines. Just have not have time to do it yet.
Here is what I do to clean a Vanguard carburetor. Pull the top off the carb. Re move the jet in the rear of the carb. Turn the key on to open the fuel shut off solenoid out of the jet. Start blowing with compressed air. Reassemble. This seems to work well for me and a lot less trouble than pulling the carb off. You can also get the fuel solenoid off with the engine in place if required. |
Finally got around to my back up mower. The fuel tank was a mess and the cut offs were full of rust and crud. See below. Got it buttoned back up, lines changed and will start it in the morning.
| Thread Tools | |
| Display Modes | |
