I think all supers have vented brake rotors, plus the pump will have a part # on the tag below the charge pump.
1872 with 50C deck 1862 with 50C deck 1641 with 48GT deck 364 snow blower IH Cub Original with deck GREEN 317 with integral sleeve hitch, front hydraulic |
Check your bushings in the axle where the knuckle goes. I had a bushing that was loose in the axle that slid down to cause the knuckle to be loose.
Well I started the tear down today. I am excited and couldn't wait much longer. I've never seen so much filth in the rear area, so I assumed the worst... that there was a leak. After I got the layers of dirt and grease, and greasy dirt out of there, I found the leak. the one axle carrier is shot. Both holes in the top are shattered and one has a broken off bolt flush in the hole, and its missing the tab on the left side. So I need to replace parts. I have all the parts here that I need, the housing and the carrier tubes. But they aren't "Super" ones. So I know I need to swap the reduction gear over from the mangled super rear to the other non super aluminum rear housing I have. Problem is I can't get either one to separate the front part off the main part to get to the reduction gear. Usually I knock stuff around with a rubber mallet and it breaks loose, but neither of these are doing so. What can I do to get them apart?
That is because behind the welch plug there is a ring holding the shaft in that goes to the reduction gear.
You will have to re shim it when you reinstall it..
![]() I'm going to be getting some braces from xtreme after all this, I want this thing to stay together.
That is good you figgered it out.
Good luck on your build and keep us posted.
How do I get #12 out? This one is making me mad. I can’t get it out.
20171001_194831.jpg |
What’s it called? I went to autozone and they said I could probably get it with bigger snap ring pliers. I have my doubts. I got them but haven’t tried it yet. I figured there was something like that but didn’t know what it’s called.
| Thread Tools | |
| Display Modes | |
