whats the preferred assembly lube on k motor when being rebuilt. my machine shop recommended gibbs lube that's used on car motors. i thought a motor oil was good. any thoughts?
Oil ONLY. Weight is up to you. I use regular 30wt, or even gear lube. DO NOT. I repeat DO NOT use engine assembly lube. A splash lube engine cannot force the lithium out. It actually will keep oil from lubricating the rod. Just use oil.
![]() ![]() ![]() No, no no..... it's a driveshaft on a Simplicity, remember? |
What he said. ^^^^^^^^^
ok thanks ill use oil then.
| Thread Tools | |
| Display Modes | |
