Old 10-03-2017, 02:20 PM
dbuck dbuck is offline
Smile
Well, then the fitting in the tank must be plugged. Take it out and inspect it.
No fitting, plastic tank with a hose barb.
Old 10-03-2017, 02:21 PM
Smile
Leave the filter installed and see if it will pull from the "gas can".
Did that, an it pull fuel just fine.
Smile
I agree but don’t try to clean it up just replace it. They are cheap.
No fitting, plastic tank with a plastic hose barb built into the tank.
Old 10-03-2017, 03:33 PM
Then you have a Tank issue.
Old 10-04-2017, 10:34 AM
Smile
I am going to take the cap off the tank and try it. Might have a vapor lock, although I doubt it. If that does not work then I am going to pull the seat pan and pull the tank.
Old 10-10-2017, 03:12 PM
Smile
Cut the fuel hose about two feet from fuel tank hose barb, no gas running out. Pump the fuel out of the tank. Pulled left rear tire to get to the fuel tank hose barb. Pull the remaining fuel hose and remaining gas ran out of the tank. The restriction was in the fuel hose, therefore not letting the gas flow. Replaced fuel hose from the tank to the filter. Primed the carb, fired the engine and it pumped fuel just fine. Thank you everyone for your replies.
Old 10-10-2017, 04:33 PM
Good news Don, glad to hear/read things are up and running again.
Old 11-04-2017, 09:25 AM
charlie g charlie g is offline
Default thanks for the reminder
another reminder of the effects of E gas. rubber hoses are only good for a limited number of years before they break down inside and collapse.
Old 11-04-2017, 09:53 AM
Any fuel line is only good for so many years. Has nothing to do with ethanol.
Old 11-04-2017, 11:07 AM
Here is some reading for you to absorb. Fuel hose is readily available that E 10 will not prematurely degrade. Same with carburetor parts.
https://www.vehicleservicepros.com/o...dern-fuel-hose
