Old 10-04-2010, 04:41 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Default Time to get the Torch & Welder Out - Implements
My pastor gave these to me today. As soon as I get time I will attempt to convert these over to sleeve hitch type implements. The plow will require the most work - some one already tried to convert it over, but it needs to be reworked.
If any one has dimensions on the plows, let me know - I need measurements from the plow to the hitch, height, etc. And maybe some ideas on how to make the plow adjustable.
Old 10-04-2010, 05:12 PM
Nice attachments, Terry! Good luck on converting them.
Old 10-04-2010, 05:57 PM
cadetfarmer cadetfarmer is offline
Thumbs up Implements
Woohoo Tmo. You got some cool stuff there, that plow looks to be and 8" or 10" and should work good for you. A disc and cultivator, now you can farm till you fall over.
I wonder what make they are? No matter, you can make em' your own and use the crap out of them.
Way to Go;
Cadet Farmer
Old 10-04-2010, 06:01 PM
Default plow adjusting
Tmo. I just took another look, if you want to adjust your plow you just need to be able to tip the point up or down to make it go in the ground.
If you need any help just give a holler, if you could get them over to Rolla, I am always welding and fabricating, be glad to help out.
Cadet Farmer
Old 10-04-2010, 08:04 PM
T-Mo's Avatar
CF,
I might take you up on that offer. I haven't been to Rolla in years, it's about time I make that trip again.
Old 10-04-2010, 09:53 PM
Default Look out I'm thinking again
Ya know Tmo. We need to know what size that plow is, 8, 10, 12inch. Cause I've got a couple 8" plows already set up for sleeve hitch, we could just swap and save us some work, since I don't use a sleeve hitch anyways.
Cadet Farmer
Old 10-04-2010, 11:10 PM
ihnick's Avatar
ihnick ihnick is offline
that digger thing looks like one my buddy has on a sears tractor
Nick.
Old 10-05-2010, 05:22 AM
cdlong's Avatar
cdlong cdlong is offline
I wouldn't be too hasty cutting that rear grader blade up. They all appear to be for a Sears, (Roper), tractor, (60s and 70s). I have a 1971 Sears Surburban SS-12. That rear blade will bring a pretty penny, they are rare. I ended up buying a Craftsman sleeve hitch rear grader blade and adapted a sleeve hitch frame to my 3 point hitch to be able to use it because I couldn't find the Sears 3 point rear grader blade. Just my 2 cents.
Old 10-05-2010, 05:35 AM
cdlong's Avatar
A couple of pics. It ain't an IH CC, but has gotten me thru the last 6 years. My father purchased new. Last winter's storms killed me with the manual front and rear blades, that's when I went looking for an IH CC with hydraulics and found the 1450. The electric lift for the 3 point hitch is even harder to find and if you do, ya best have deep pockets.
Old 10-05-2010, 07:10 AM
T-Mo's Avatar
Cadet Farmer
Sounds like a plan to me. I don't think this ground here can handle anything larger than a 10 inch plow, so 8 inch should be fine.
