Old 12-23-2017, 08:49 PM
Bamma Bamma is offline
Default Steering
Hello
I need to take me steering sector out of my 782D and do whatever is needed. Would like to know the best way to go about it. Thanks
Old 12-23-2017, 09:03 PM
Drop it out the bottom
Old 12-23-2017, 09:09 PM
bsm2003
Guest
Posts: n/a
http://www.onlycubcadets.net/forum/s...ead.php?t=4631
http://www.onlycubcadets.net/forum/s...ad.php?t=13226
These should get you there.
Old 12-23-2017, 09:11 PM
Thanks guys
Old 12-26-2017, 05:27 PM
j knight j knight is offline
Originally Posted by Bamma View Post
Hello
Call one of the sponser's and find one with the three turn lock to lock.
Old 12-26-2017, 05:39 PM
What Joe said.
Old 12-27-2017, 01:55 AM
Can you take the steering box off without taking the whole column out
Old 12-27-2017, 01:58 AM
Can I take the steering box off without taking the whole steering column off
Old 12-27-2017, 02:23 AM
No. It's all one piece. Steering box is the column. You have to remove the column, but not the dash.
You take it out the bottom.....
Remove the mower deck (if it's on).
Remove the subframe for the deck (if it's on).
Remove the steering wheel.
Remove the tie rod.
Unbolt the hyd valve and support it.
Remove the hyd valve plate.
Remove the lower bolts.
Jack up the front
Drop it out the bottom.
Old 12-27-2017, 07:45 AM
Down load the service manual
http://www.onlycubcadets.net/forum/s...ad.php?t=25397
