Old 01-05-2018, 09:30 PM
DownNdirt's Avatar
DownNdirt DownNdirt is offline
Default Have a few questions about my 1250...
First question is what thread size bolt do i need to hold my side panels on? (Like 5/16 or 1/4 or something along those lines) I've tried looking everywhere and can't find anything on them. Second and final question is what diameter is the trunion shaft? I will eventually be pulling off my fender pan and repairing the trunion ( should have done it when i had the transaxle out but i didn't think it would be as bad as it is,) and my damper plate is fairly loose. I think I'm going to reweld the trunion, tighten up the damper plate and replace the springs while I'm in there as it seems that's where most of my creeping problems come from. As always, any answers are greatly appreciated.
'78 1250, '79 1450, '77 1000
Trapped and released: 124, 1000, 72, 1211
(JD) '70 140 H3 patio yellow, '74 140 H3, '87 332 diesel
Attachments: too much to list
Old 01-05-2018, 11:13 PM
1/4" to hold the side panel on. Don't know off hand about your second question.
Old 01-06-2018, 06:07 AM
jsoluna's Avatar
jsoluna jsoluna is offline
Thread size is 1/4"-20 for side panels.
If you are talking about shimming the pivot of the damper and control plates:
Damper 5/8" ID Shims
Control 1/2" ID Shims
Grab some .005 and .010 shims for both sizes so you can dial it in, as well as new retaining rings. It helps tighten things up if they aren't distorted.
More info here:
http://cubfaq.com/hydrolurch.html
http://www.solunagarage.com
Old 01-06-2018, 12:51 PM
DownNdirt's Avatar
Okay thank you guys very much. I'll have to find or pick up some bolts this weekend. Thanks for the info on the hydro shimming process. I just remembered reading that cubFAQ article about a month ago but forgot about it. Just need to find a spring for the front (seen one on ebay for 10 bucks. Maybe I'll pick it up.) And get the shims.
Old 01-06-2018, 02:18 PM
Dart1917 Dart1917 is offline
For the spring pick up a screen door spring at the hardware store and rebend the ends to fit. Probably have to shorten it a little too. Should cost about 3 bucks.
Old 01-06-2018, 02:37 PM
twoton twoton is offline
I find it more convenient to use knobs instead of bolts. You can usually find them in the hardware bins at your local hardware store. I usually use them in conjunction with a SS fender washer. I also find that a throttle or clutch return spring works well at the front.
Old 01-06-2018, 05:22 PM
Put a piece of rubber hose over the spring, it need not be full length, any old useless fuel line will work, it keeps the spring from vibrating/making a weird sound. ( harmonics)
If you like to tinker and remove the side panels often,
put the bolts in from the back side and pick up a couple of wing nuts or knobs as suggested,---- makes it easier/quicker on/off
Old 01-07-2018, 03:34 PM
DownNdirt's Avatar
Ok guys, i just thought of one more question. When i was installing my hydraulic lift, i somehow broke a terminal of my pto fuse holder. I rigged up a blade fuse holder and quickly realized it doesn't work with the pto. Can i just swap the light fuse wires for the pto and use the blade fuse holder for the lights? I know it probably sounds silly but i know the lights will work fine with the blade fuse, but i don't know if the two dash fuse holders can hold the same current. Also, thanks to all the guys who helped out with the first questions. I'm still sort of a newie to the ins and outs of Cubs. All I've ever owned was deeres and thought it was time to branch out to more brands.
Old 01-07-2018, 04:35 PM
No reason the blade fuse holder wouldn't work with the PTO. You must have another issue. Both fuse holders on the tractor are identical.
Old 01-08-2018, 02:14 PM
DownNdirt's Avatar
I popped in a 10 amp after plugging in the pto wires, flipped on the pto on (with no load) and it blew it almost immediately. I'm just gonna swap them around so the pto is on the dash fuse and the lights are on the blade fuse.Only reason i asked was because the lower fuse holder looked different than the top. But i don't have a blower or tiller for it so i don't need the pto until spring when i throw the deck on.
