Old 02-08-2018, 08:32 PM
Gompers Gompers is offline
Originally Posted by Joe_K View Post
I sent Jeff in PA a PM but I'm sure someone else know the answer. The factory lift rod for the 782 looks like it has a bend in it. Will a straight adjustable one like Jeff in PA sells clear the frame & side panels on a 782? There's not as much room as the older Cub's.
Lift rod will clear fine, at least on a QA-36A/B/42A. The arms that go between the blower housing and the frame need to have the bend in them, though, or they will hit the front tinwork.
Hopefully you can see what I mean in this video.... Video
Old 02-08-2018, 09:10 PM
Joe_K Joe_K is offline
Thanks for replying, the link to the video doesn't work.
UPDATE: Link Fixed - Admin
PM replied to.
Anyone know if my adjustable lift rod will work on the 782. 28" to 32" adjustment length
Jeff
Thanks, sent you an email.
Old 02-09-2018, 08:50 PM
Lift rod ships tomorrow, you should have it Monday. ( provided the post office does their job )
Thanks
Jeff
Old 02-09-2018, 10:38 PM
Thanks
Jeff
You're the man!!
Old 02-10-2018, 11:53 AM
Now take a pix or two of the cleared drive way and the little red worker that did it.
Take it to Dad @ the care facility, and thank him for it, and the good care he gave to it and how special it is to you.
Old men appreciate that.
and don't forget to give him an extra hug.
Just had him up today, showed him how easy it starts and my clear driveway.
Old 02-10-2018, 07:48 PM
jbrewer's Avatar
jbrewer jbrewer is offline
I'm sure he really appreciated you fixing it AND showing him that you've cared for something that meant a lot to him thru the years.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 02-12-2018, 06:01 PM
Thanks
Jeff
Got it today and tested it out. It's very well made, and it's VERY close to the frame on a 782 but it works. I used a few washers to space it out. All the snow melted today but I tested it out on a dirt pile. Just threw some primer on it, I'll hit it with some IH white tomorrow. Thanks again.
Old 03-01-2018, 10:42 AM
I'm wondering if this is common. I can run the 782 all day it seems with the headlights off, and it will start back up even after sitting for a week. If I run it with the headlights on at night, it will not restart without a charger on it. Battery is new, does it sound like the charging system is weak? I'm an automotive guy, so I'm familiar with alternators, but I never messed with small engines besides basics. I looked through the manuals on this site but I can't find a charging system troubleshooting guide.
Old 03-01-2018, 11:36 AM
If running with lights on, the rpm's have to be high enough to show a + on the ammeter or you will eventually deplete the battery charge.
If you are running full rpms and not showing a + charge, it needs to be investigated.
