Old 03-06-2018, 08:46 PM
ironman's Avatar
ironman ironman is offline
Jeff in PA makes the pump adapters that allow you to use the 2000 series or the CV style drive shafts. 1st pic is the type needed for something like a 782 with a 5/8" round shaft with the spirol pin, the 2nd is for the Supers or Cyclops that have the 5/8" nine spline shafts.
Awesome! Thank you for that info. I have a worn rear coupler on my 149 and I already have a 2000 series drive shaft. With Jeff's adapter I should be good to go. Apologies for highjacking the thread.
Old 03-06-2018, 09:59 PM
Sam's talked about that conversation like 100 times. I'm surprised you didn't know....not picking on you. But it's been mentioned a lot.
Old 03-07-2018, 07:11 AM
ironman's Avatar
I did know, but I always assumed that it was done mainly to replace all the junk at the flywheel end because it is a simple bolt-on transition. I wasn't aware there was an adapter available to do the hydro end. I will be contacting Jeff today.
Old 03-09-2018, 08:44 AM
sorner's Avatar
sorner sorner is offline
Jon actually the 2000 series shaft is a nice snug fit to the 5/8" shaft used on most older Cubs. That's what I did on my 149 at the engine end. The 149 drive cup was shot as was the end of the drive shaft. Once I got the length as I wanted it I marked it, pulled it out of the tractor, drilled it and put a 1/4" spirol pin in it. Then I reinstalled it.
+1 snug fit. The one I did I had to "persuade" it on with a rubber mallet.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
