Old 03-13-2018, 02:20 PM
2wheelsadam 2wheelsadam is offline
Default How a rear sleeve hitch works with hydraulic lift?
Could someone be so kind to explain how adding a sleeve hitch works on my 1650. It has hydraulic mower lift so does sleeve hitch hook to that some how? Thanks and pics would be really helpful😁 not really understanding the whole sleeve hitch set up. Thanks
Old 03-13-2018, 03:22 PM
First, welcome to OCC.....
Click on this link...... Sleeve Hitch
Specifically, here is a Wide Frame Lift Assembly.
Sleeve hitch works off the same lift cylinder as the mower deck. So does the front lift for a blade or snowthrower. They all use the same system. So, you can only have one implement on the tractor at once. They all 3 lift and lower at the same time. Pretty simple set up.
Old 03-13-2018, 03:54 PM
Default #3 bar?
So the #3 bar in the pic goes to lift cylinder?
Old 03-13-2018, 05:51 PM
odel33 odel33 is offline
#3 part fits to rocker shaft
Old 03-13-2018, 07:34 PM
Default Hitch
Yes but the other end must go hydraulic cylinder?
Old 03-13-2018, 07:45 PM
Terry C's Avatar
Terry C Terry C is offline
Pull your tunnel cover off and you will see where it hooks to. # 3 runs inside the right hand side of the frame.
A piece of solid rod goes in the rearward facing hole in #2. That’s what does the lifting is the rod in number 2
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 03-13-2018, 09:07 PM
odel33 answered correctly. If it makes more sense to say it attaches to a cylinder, then sure. In a round about way it is.
Go to this link.... WF 3 Point Installation
Right hand side, at the bottom "WF 3PT Install"
Old 03-13-2018, 09:45 PM
Here is a copy of the instructions.
https://drive.google.com/open?id=17r...iZLluVz5qm-F_w
