Old 04-03-2018, 08:53 PM
Bending the copper isn't hard. Making it fit isn't hard.... but it's harder than running a hose. And the fittings cost more.
Old 04-03-2018, 08:54 PM
Originally Posted by DeltaCub View Post
It's not one of these "gays" is it?
Old 04-03-2018, 09:16 PM
Those seems more like John Deere people.
Old 04-03-2018, 09:30 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
My apologies to the original poster....and John Deere!
Queen Of The Quietlines!
Old 04-03-2018, 09:41 PM
OMG! That's funny sh!t!!!
Now that is gay,lol.....
Old 04-03-2018, 11:47 PM
Line is easily made.
Old 04-04-2018, 09:06 AM
nnero nnero is offline
hahaha
Very nice, that looks great! My fuel inlet is on the opposite side of the carb. I want to make sure nothing rubs because I have to run the lines a little bit longer.
Thanks for the pictures and tips.
Cub Cadet 107
Old 04-04-2018, 09:37 AM
I saved this piping arrangement from years ago. The guy did a very good job.
Old 04-09-2018, 08:34 AM
Wow another great job! I got my sediment bowl installed with new line. I could not find the right fitting(nipple) i wanted that threads into the tank. I will fix that later on, the bowl just sits a little lower. Ill take pics later.
Now i need to take off the rear fenders to start diagnosing my oil leak and so i can clean it all off as its covered in oil right now. I bought the cork gasket between the hydro pump and rear end which is where I suspect its coming from. I need to do some reading about disassembly.
Two questions:
I need new front tires and found a really good price on some carlisle 16.5 6.50-8 4ply. What I have now are 16 6.50-8. I assume the height difference wouldnt cause any issue with clearing/turning?
Also, did the the hydrostatic tractors have a mesh or solid driveshaft/clutch cover?
Thanks
Cub Cadet 107
Old 04-09-2018, 10:14 AM
The tank should have a male fitting comingout of it. New sediment bowl should be female. No fittings needed.
Check the hydro release valves too....
Two questions:
The tires are the same size that you listed. They don't make a 16.5x6.50-8. Someone typed wrong.
The ply rating doesn’t affect height. Not a noticeable amount anyway. 4ply is the usual ply rating.
Mesh. No tractor had a solid cover. That's an aftermarket replacement.
