I have a GT2186 and it started to have a problem when you push the brake pedal in it won't start and it sometimes take maybe 6-8 times till it starts. I was thinking it could be the switch on the parking brake, any help would be helpful, thanks in advance
I have several mowers with engines just like yours. You could have battery problems or connection problems. You could need to do the starter relay upgrade. Here is a link.
http://www.onlycubcadets.net/forum/s...t=1864+starter
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
2 things could be happening comes to mind.
One, could be the brake safety switch is defective and needs replaced. Two, could be the ignition switch is failing and needs replaced. I suggest you check continuity of the brake safety switch first with a meter or test light. If ok then check the Ign switch for power to the solenoid activation wire. Report back with your results. |
the brake lever was not always hitting the switch, we had to take it apart and make a bracket and fasten it on the brake lever and now it starts like new
| Thread Tools | |
| Display Modes | |
