Old 04-06-2018, 07:30 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Default 2284 But honey it was to nice to pass up.
I've been watching for donor motor for my 1872 and found this. This was way to nice for a donor, so I have other plans. I'm not going to sell it, but what do you think it is worth? It is 858hrs and all solid plastic. No issues that I can find thus far.
Old 04-06-2018, 11:07 PM
john hall's Avatar
That thing is BORING. Anything that looks that nice probably only needs an oil change and blades sharpened. I bet your dash lights even work!
So did it come with the Sam Mac approved hold hold down device?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 04-06-2018, 11:33 PM
He did change the oil. He claims he changed oil every 50 hours and clean as it was I believe him. Blades do need sharpening. All lights do work. I should have taken the Sam Mac hold down off for the photo. I installed the hold down for the long trip home. I've seen to many hoods along the highways. Even though I never went over 40mph. Mapguest 3.7 miles, 9 minutes. This trip makes up for the St.Louis to K.C. run.
Old 04-07-2018, 12:27 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Wow that is a nice tractor! 2284's have got to be pretty rare.. I've never seen one in these parts at all!
Congrats on the great score!
Jay
Proud owner of the following:
Old 04-07-2018, 07:00 AM
That is sweet! Should be worth a couple grand anyway.
Old 04-07-2018, 08:35 AM
IHCubCadet147's Avatar
Nice tractor!
Old 04-08-2018, 07:23 AM
Dirty Steve's Avatar
Congrats on the 2284
Old 04-08-2018, 10:03 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
looks real nice.......except for those scratches in the hood from the bungee hooks, LOL.
Old 04-10-2018, 08:42 PM
It appears I have electrical issues. It started and loaded on the trailer just fine. Got home started and unloaded off the trailer ok. Then it stuttered in the yard and quit at the garage door. Thought maybe out of fuel, added a couple of gallons. It starts and dies when you let go of the key. Saw electrical tape on the connector on ignition switch. Pulled that off and the black wire terminal was toast. Pulled that apart and replaced terminal and block. Still same thing start and quit. I'm leaning towards a bad ignition switch. Do the headlights stay on all the time? The switch seems to have a start, run with lights and off positions only, is this correct? My 1811 has start, run, run with lights and off positions. I do see the parts book calls out 2 different switches for the 1811 and 2284. When I turn the key on only I do hear and feel the fuel solenoid click. But if I touch the key just a little the solenoid clicks in and out and lights stay on. Any thoughts guys?
Old 04-10-2018, 10:27 PM
john hall's Avatar
Take a look here about some of the issues I found with mine. There are some links to various pages here on OCC that have some info you should read. I don't remember if I fixed my switch or replaced the whole thing--think I changed the whole thing. Seems I have REALLY bad luck buying Cadets with bad key switches.
http://www.onlycubcadets.net/forum/s...t=47313&page=3
2072 w/60" Haban
