I don’t think he does anything special. When he gets done licking windows, I’m sure he’ll be along to comment.
Queen Of The Quietlines!
The snozberries taste like snozberries
Tim, I do believe the bracket Deltacub linked you to uses the same holes as the meow 0 setup, so it will be good.
My al rear 782 does great with the extreme u bracket for several years now. Make sure screws have correct length of engagement
Craig |
Here's the bracket I have. The bracket came on an 1810 parts tractor and the tractor had a NY plow day sticker on the dash so I assume it was used to plow at least once. I'm just gonna use it and if it breaks, it breaks.
Maybe that it why it is off the tractor, you do not want to break your rear end.
Tim, weld some side supports to it so it will mount onto the axle carriers. Will also pull on the sides and not just on the back.
It was still on the rearend about a half hour before the picture was taken, the bolts and threads looked fine.
I will if i have the time. I have a good amount of work to do before next Friday so well see what i can get done.
| Thread Tools | |
| Display Modes | |
