CADplans, I agree, but what I need are the dimensions especially for the lift bar and attaching hardware as shown in the picture I posted earlier (part # 3 & 4). Is the bar straight or does it have a bend in it on its way to the forward connection point. I can guess at the rear cast portion dimensions and assume that the lower lift bar is 90 degrees from the implement attaching point. Should I assume that it is in fact 90 degrees? What is the distance between the center of the thru shaft and the center of the lift bar connection point?
I renamed this as your asking about the rear lift and not the sleeve hitch.
Sounds good, anything that will help is much appreciated
Here is the bar measurement I got from a member here
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
here is another that has the other part you wanted
Thank you very much bocephus1991, I will get to work building these parts and send in a picture of the finished product when completed.
Now all I have left to do is get the dimensions of the tiller mule drive and I will be golden.
you should make a 0 category hitch and i frogot to mention.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10:
What diameter rod is in the upper left corner of the picture? Building my own hitch and lift myself on a 129
| Thread Tools | |
| Display Modes | |
