Old 06-18-2018, 12:45 PM
Nato527 Nato527 is offline
125 getting ready to mow
Old 06-18-2018, 12:50 PM
Looks great! What are the decals on the tunnel?
Old 06-18-2018, 01:31 PM
Ha! That was my wife " helping " me with the rest of the decals that came in the kit. " thanks honey, looks great" . I don't think they even go on that tractor. Don't have the heart to take them off.
Old 06-18-2018, 01:47 PM
Just swapped out the front end with one off 1811. It raised the front up a little, need to adjust the mower
Old 06-18-2018, 07:26 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
I thought the front rims and spindles looked a little different!?
How does she steer?
Jay
Proud owner of the following:
Old 06-19-2018, 09:48 AM
It steers ok, I guess. It's almost like it oversteers, if you crank it all the way to the left or right it's hard to straighten back up. Not sure if I need to put stops on it or something. This picture is when I was mocking it up. Had a couple front ends and tires to pick from. These are different wheels and tires than what's on there now. What's on there now doesn't stick out quite as much. Any advice?
Old 06-19-2018, 10:48 AM
cooperino's Avatar
Usually do not see the tires standing that plumb... Usually looks like this " \ / "
Not like this " l l " Without the proper camber the tractor steering will have less return-ability to center.
Old 06-19-2018, 01:31 PM
I gotcha, makes sense. I used all the parts off the donor tractor. Tie rods, steering link, etc.... it's a little sloppier than my old front end. I had to donate that one to my dads 104 I did for him. Could that be what it is? Worn out spindles? There's no adjustment for camber is there?
Old 06-19-2018, 02:21 PM
Terry C's Avatar
Terry C Terry C is offline
Not one that doesn’t require welding.
You should start a thread in the IH section and get some other people to look at it too.
More people view that section
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-07-2018, 10:01 PM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
Here's the 1250 washed and waxed with the headlights hooked up.
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
