Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 07-02-2018, 09:26 AM
cwsink cwsink is offline
Default Electrical problem- Voltage regulator?
I’ve got a LT 1050 with the Briggs 20 horse motor. My problem started when the battery kept losing charge, I concluded that it wasn’t getting charge. I considered that it might be the voltage regulator, but now the engine won’t even start. When I crank it, it will fire maybe once or twice then nothing.
Not sure what the issue is now. Any thoughts?
Old 07-02-2018, 10:11 AM
Well it stands to reason if the battery is bad or discharged, it will not start.
I would charge the battery, then load test it or have it tested where they sell batteries. if bad/weak, get a new one.
Then see what happens.
Old 07-02-2018, 11:07 AM
The battery is not the issue. As I mentioned it will crank the engine but the engine won’t fire.
Old 07-02-2018, 11:10 AM
cooperino's Avatar
If it cranks the engine and it wont fire there is another issue besides charging.
Old 07-02-2018, 11:21 AM
cooperino's Avatar
Need to know more of what you already checked..
Got gas? Getting gas to carb? Getting spark? Check your safety switches?
Etc Etc.
Old 07-02-2018, 11:26 AM
cooperino's Avatar
You sure that's got a briggs in it? I see the 1050 listed as having a kohler 25. Pre 2008 it could have been command or courage. Did you or someone swap engines?
Old 07-02-2018, 11:44 AM
Originally Posted by cooperino View Post
Need to more of what you already checked..
Etc Etc.
There is about 6 volts coming from the voltage regulator. I'm not sure about spark, I assumed the problem was either the V/R or alternator originally when I wasn't charging but the engine is running.
I'm assuming the new development with the engine not starting is linked to the same issue; but I don't know and I'm looking for clues.
Old 07-02-2018, 11:45 AM
It's a Briggs, but it would have been swapped by someone else. Just bought it earlier this year.
Old 07-02-2018, 02:41 PM
Possibly it's two different issues?
Old 07-05-2018, 06:46 PM
cooperino's Avatar
Yes. 2 issues. If you have a fully charged battery regardless if VR is working or not it should still start. So, You need to check for spark for starters. If you have spark chances are it is a fuel problem.
Tags
electrical problem
